Data Protection
Wrong size detected using snapdrive storage create command on Solaris
limk
Hi All,
I encountered a weird stuff here, when i use the "snapdrive storage create " command to create a lun size of 1gb to mount on filesystem /mnt/test, and from the "df -k" command it shows only less than 50MB for that particular filesystem.
Wonder if anyone have encountered anything similar to this and can advice me on that. Thanks!
regards,
Ken
8 REPLIES 8
knshiva
Please let us know the details of configuration on which SDU is being used.
limk
The environment comprises of :
SDU4.1.1
Solaris 10u8
Host Utility Kit (5.1)
knshiva
this issue has been reported internally through a bug and work is going on to resolve it.
ogra
Is this bug a known issue in the above mentioned environment ?
We have a implementation going on, we haven't seen this issue. Could you please forward the bug id.
-Bakshana
knshiva
394820 [2A] - "Sol10 U8: Storage create is not allocating the actual size for fs"
limk
Do you know if the patch or new release coming out soon. I need it urgently to continue my deployment. Thanks!
ogra
Thanks, I think this is only for Veritas and not mpxio as I see the Burt.
Thanks anyways.
limk
This issues applys to non veritas and mpxio as well.
