Data Protection
XCP Maximum Values
shirotan
I ran XCP SCAN with the -stats option.
There was a Maximum Values.
What is the unit of the Dirsize item?
Byte? MByte? Bit? Number of files?
I think this item is necessary to set Maxdir of the destination FAS when designing the migration.
== Maximum Values ==
Size          Depth    Namelen   Dirsize
275GiB         24             245          56654
== Average Values ==
1.55MiB        10              23                  11
1 ACCEPTED SOLUTION
Mjizzini
The unit is in  Kb
Vol show
[-maxdir-size {<integer>[KB|MB|GB|TB|PB]}] - Maximum Directory Size (privilege: advanced)This optionally specifies the maximum directory size. The default maximum directory size is model-dependent, and optimized for the size of system memory. You can increase it for a specific volume by using this option, but doing so could impact system performance. If you need to increase the maximum directory size, work with customer support.
3 REPLIES 3
hmoubara
shirotan
Hello
hmoubara
Thank you for your replay.
But I'm not asking what Maxdir is.
I understand that the DirSize of "Max Value" displayed when scanning with the "-stats" option is the maximum directory size contained in the target to be scanned.
Based on this information, I understand that the FAS MaxDir for the migration target should be set.
Therefore, I would like to know the unit of this number.
Mjizzini
The unit is in  Kb
Vol show
