Data Protection
how remove snapshoots from vault and then policy
GREGD
Snapcenter 4.1 , im new in snapcenter, we create at the begining a few policy after 5 days we change our backup strategy and create a new policies. Now we cannot delete the policies because there should be a backup attached. But i know that that retention should be over .
i check the databases where this poliy was attached .  I remove manually the snapshoot which was attached to local copies and allso make check thaz al backups should be deleted.
but when i check the database.
i get this. under mirror the snapshoots are deleted. you see  mirror there should be 32 copies but graphich shows 36 date is 25.9.2018
under vault i see that there are 36 copies snapshoots
policy4 vault.JPGyou see there are also 21-24.9.2018.
so how can i delete this snapshoots that mirror and vault be the same? I dont remember that i should make a seperate retention policy of vault.  So how to delete it or synchronize it.
Should i do it direct on netapp? Or how can i resolve this?
3 REPLIES 3
stanton
You can see the retention on the ONTAP cluster.  Use the command:
snapmirror policy show -policy <Policy name> -instance
See the Data Protection Power Guide for more information on the command.
GREGD
Its strange , now when i check today the database in snapcenter. the number under mirror and vault are correct and older snapshoots where removed.
I only get the first error that i cannot remove policy.
but i will check it with your commands.
GREGD
Now i check with powershell where which policy is added  . and resoult the policy is not added.
But i cannt  still not remove it.
https://kb.netapp.com/app/answers/answer_view/a_id/1081035/~/when-attempting-to-delete-a-policy-in-snapcenter%2C-the-deletion-fails-stating
