Data Protection
iSCSI and Fibre Channel on the same host
Willybobs27
We currently have LUNs presented via iSCSI to two filers.
We want to present LUNs to the same Windows host on two new filers via Fibre Channel
SQL databases will then be migrated from the iSCSI LUNs to the Fibre Channel LUNs using Snapmanager for SQL
Can this be done?
If so how can I tell if the DSM was installed with both the iSCSI and Fibre Channel options?
4 REPLIES 4
radek_kubka
Hi,
Hmm, why not SnapMirror volume(s) from old filer containing LUNs in question to a volume on a new filer? Then you can break the mirror & attach migrated LUNs via SnapDrive.
Regards,
Radek
Willybobs27
They are Windows 2000 Clusters so I think there will be an issue with disk signatures.
radek_kubka
Replicated LUNs will be identical as the original ones, including their signatures. I don't think Windows will attempt to re-signature them when attached to the host.
Why not try this out? Your original LUNs will remain intact all the time anyway.
Regards,
Radek
Willybobs27
Because I have Mission Critical systems hosted and such a procedure wouldn't get through Change Control.
Unfortunately I don't have test infrastructure so I have to play this safe.
