Data Protection
snap drive quick guide
Rawat_Sunil
Would be requring the Snap Drive Quick Reference guide.
Regards,
Sunil Rawat
2 REPLIES 2
hariprak
Hi,
For SnapDrive for Windows, you can refer below link,
https://library-clnt.dmz.netapp.com/documentation/docweb/index.html?productID=62028&language=en-US
For SnapDrive for UNIX, refer the link,
https://library-clnt.dmz.netapp.com/documentation/docweb/index.html?productID=62096&language=en-US
Thanks
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Rawat_Sunil
Thanks for your responce but both the link is not opening.
Request you to please resend the same.
Regards,
