EF & E-Series, SANtricity, and Related Plug-ins
Drive failed on E-series 2700 cause controller go offline
King86
HI community
We have an E-Series 2700 and the issue we are having is the after there is a drive failure the primary controller goes offline but does not get back online automatically, we have to manually change the state to Online after we replace the drives.
So I am wondering:
1. Why does the controller go down? Is this normal behavior?
2. If it is then why doesn't it come back up automatically?
Any help or speculation would be helpful, thanks
1 ACCEPTED SOLUTION
NetApp_AU
Hello,
It is not normal behavior for a controller to go offline or reboot after a drive failure or replacement. I recommend collecting a support bundle and the seven segment error code on the back of the offline controller, and then open a case with NetApp Support for further investigation.
Team NetApp
3 REPLIES 3
NetApp_AU
Hello,
Team NetApp
MitchBlackburn
In general, a drive failure should not cause a controller failure. You should contact support for this issue so it can be resolved.
King86
Thanks for the input guys. Much appreciated.
