EF & E-Series, SANtricity, and Related Plug-ins
Hot add disks to Live E2760 controller-drive tray
JasonDrury
I can find documentation to hot add a new disk tray to a running e-series, but I can't find any documentation describing the procedure to (hot?) add a number of individual disks to a live e-series disk tray that isn't fully populated.
Is it similar to the "replace a disk" procedure but without doing anything related to pulling out a disk first?
Thanks,
Jason
2 REPLIES 2
Sahana
Hi
Please refer https://library.netapp.com/ecm/ecm_download_file/ECMLP2526650 page 123 to add disk shelf.
To add only the drives to an existing shelf refer to step 10 in the same procedure
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
alexfert
I also have the same question about adding disks to an existing system.  When I click on the link, i get a file not found error.  Can you please point me in the right direction of the doc?
