EF & E-Series, SANtricity, and Related Plug-ins
Low perfomance with DA is On (E2812, iscsi)
victorzaytsev
I read the phrase in the documentation - DA is not compatible with ISCSI, but when creating Volumes on the E2812, DA is switched On by default.
With DA on, performance is significantly reduced - 10 iops on read, 200 on write, latency – 100 msec.
It is normal?
If DA is off, the performance is normal.
1 ACCEPTED SOLUTION
2 REPLIES 2
victorzaytsev
Thank you.
