EF & E-Series, SANtricity, and Related Plug-ins
e-series controller conversion to a disk shelf
sblanco731
Good evening my NetApp Community!!
I did a bit of hunting, but didnt find any legit documentation on the subject which makes be believe that maybe its not a support solution.
I want to take two e-series 5660 systems, convert the controller shelf to a standard shelf and add it to a e-series 5660 system as just a simple expansion shelf.
Data aside, is this a supported conversion?
As always thank you for your assistance in advance,
Steve
1 REPLY 1
MitchBlackburn
This is something you can do, but I would suggest you contact support to walk you through the steps and any gotchas that can occur. Mitch
