EF & E-Series, SANtricity, and Related Plug-ins
how to revive a volume group in Santricity
ShahbazRiaz
The Client has Volume Group with RAID-6 and one disk slot#22 was fail then by mistaken client removed 02 more disks in RAID, so volume group is in fail status, can any body help to recover/revive a volume group in Santricity 11.30
1 ACCEPTED SOLUTION
Vnichola
Original disks will be needed as well, but as indicated a support case should be raised as recovery will require the hot spares drives be unassign and running several commands to prevent reconstruction and complete recovery.
2 REPLIES 2
Ontapforrum
If the system is under valid support, then please call NetApp Technical Support or log into the NetApp Support Site to create a case.
Vnichola
