ONTAP Hardware
How to "create" a spare disk in a v3240 that is fully aggregated and has none.
NETAPPDOW
Hi;
NetApp Release 8.2.3P4 7-Mode
Fully populated v3240 (600GB SAS disks), but no spares. Had to replace a few pre-fails.
There's about 3 TB "available space".
How do I create a Spare disk out of one of the ones in use?
Thanks.
Gregg
1 ACCEPTED SOLUTION
aborzenkov
Either convert RAID_DP to RAID4 and get one spare for each raid group or backup, recreate aggregate, restore.
if you have more than one aggregate you may be able to move data off one of them (temporary).
When choosing between RAID_DP without spares and RAID4 with spares I’d prefer RAID_DP.
3 REPLIES 3
aborzenkov
NETAPPDOW
Thanks.   Can't do that.  So there's no way to select a disk, move data off, and zero it out  for a spare?
andris
No.
