FlexPod Discussions
Problem with the cf takeover and cf giveback in the FlexPod
thomastrendel
Hallo,
Problem is am I doing a cf takeover with Kopf1 (vfiler with NFS) on it so that head takes over two. Run all the VM's lying vfiler on the NFS without any problems.
I'm doing cf giveback one but so that everything works again on Kopf1, the VM's stand. Only two ping dropouts are Ping on the vfiler with NFS.
What me but in the then in the nexus noticed is that here, I get these Errors: In the Annex
May be that cf takeover and cf giveback Problem??
Config from the nexus in the annex.
Many tank times in advance for a small tip
Thomas
1 REPLY 1
gerdhecken
Hi Thomas,
this is not a Problem with the functionality from the NetApp FAS Systems.
It seems so that there is a missconfiguration with the FCoE.
Can you post me the configuration from the other Nexus Switch?
We have a similar Environment with a converged Network Uplink for NFS and FC traffic over the same Cable.
Regards
Gerd
Unique on both N5K
NK51:        N5K2:
vlan 3500        vlan 3501
  fcoe vsan 3500        fcoe vsan 3501
  Name XXXXXX        name XXXXXX
vsan database        vsan database
  vsan 3500 interface vfc15        vsan 3501 interface vfc15
  vsan 3500 interface vfc16        vsan 3501 Interface vfc16
nterface Ethernet1/15
  description FCoE- und NFS Link FAS3240-C1-e2a
  switchport mode trunk
  switchport trunk native vlan 21
  switchport trunk allowed vlan 13-21,3500                                                            switchport trunk allowed vlan 13-21,3501
  spanning-tree port type edge trunk
  channel-group 110 mode active
interface Ethernet1/16
  description FCoE- und NFS Link FAS3240-C2-e2a
  channel-group 111 mode active
Same on both N5K
vpc Domain 20
interface port-channel110
  description FCoE- und NFS Link FAS3240-C1-e2b
  vpc 110
interface port-channel111
  description description FCoE- und NFS Link FAS3240-C2-e2b
  vpc 111
interface vfc15
  bind interface port-channel110
  switchport description FAS3249-C1-2b vFC FCoE-Verbindung
  no shutdown
interface vfc16
  bind interface port-channel111
  switchport description FAS3249-C2-2b vFC FCoE-Verbindung
  no shutdown
