FlexPod Discussions
Upgrade DOT in FlexPod solution
ADDEDMARIORF3
Hello Team,
I'll execute an update in NetApp DOT storages (from version 8.1.1 to 8.2) and the storages are part of a FlexPod solution. Has anyone done this before or has any recommendation?
I'll use upgrade advisor to get a action plan.
Thank you very much.
MRF
1 REPLY 1
GRAEMEOGDEN
Just check the IMT that the UCS firmware you're running is supported on the new version of DataONTAP
http://mysupport.netapp.com/matrix
