Legacy Product Discussions (RO)
Old FAS270 java problems
david_w_qualls
I have an old FAS270 that I want to put back into action.  everything works on it but the web interface.  I am attaching a webshot of the errors.  Any help wwould be appreciated.
David
1 ACCEPTED SOLUTION
scottgelb
I would re-push ONTAP again... and check if tls is disabled on the browser.. or tls.enable on the controller.  The latest 7.3.5.1P4 is supported on the 270.. make sure you use the M Mips code.
3 REPLIES 3
david_w_qualls
I guess I should ask another question.
What is the latest version of DataOnTap that I can run on this thing?
Would running 7.3.3 cause the gregorianCalendar issue?
David
scottgelb
david_w_qualls
I ran a 4a on the thing and I am downloading 7351_m.  Will try to push DOT again tomorrow.  Thanks for the info!!
David
