Legacy Product Discussions (RO)
configuring ndmp.enable option using the sdk failed.
__david_elam_11499
Hi ,
i'm trying to use the SDK to change OnTap options via the perl API.
most of the options are working great but two of them seems to have problems :
1) timed.proto - even tough the man pages say that sntp is supported and i can run it using the cli
it won't work on the sdk (workaround i found is to use ntp instead)
2) trying to set the option ndmpd.enable result in "No such option: ndmpd.enable, again
setting it from the cli work's fine.
i'm working with OnTap 7.2.4 on FAS270 and using sdk-3.0R1 with perl.
Thanks in advance for any reply
David.
1 REPLY 1
nagendrk
I tried to set ndmpd.enable option using APIs. I see the same issue. Looks like a bug to me.
