Legacy Product Discussions
I have a shelf ds14mk2 with 300gb fc hard disks on a FAS960 equipment, that has the following errors:
Power led on (green)
Faul led off
Loop A led on (green)
Loop B led on (green)
System led on (amber)
I ran the enviroment comand and showed "no errors detected"
What should i do? or what does this errors means, Thank you!
It's a 7 or 8 year old controller with no modern software support... iirc... (r200 images will work)
1. Upgrade the shelf firmware.
2. Reboot the shelves (disruptive!)
3. Hit the thing with a big hammer and have it taken to electronic recycling.
