Legacy Product Discussions
Ontap upgrade to v6.3
johnchang
Hi,
I know this may be a tough question to ask since the filer F740 and the os ONTAP v6.1 are quite old but we still use these in our test environment and I'm having some problems that I can't get support through netapp as we ran out of support.
My problem is that the ONTAP OS no longer boots and I was trying to upgrade to v6.3. I have downloaded the v6.3 on the floppy disks and tried to install but does not work, can anyone tell me how I would go about installing the new version?
39 REPLIES 39
johnchang
OK, based on the drawing that I just saw, I have 2 FC9 shelves on each F740 filer.
So, In order to execute your recommendation, I would basically power down the 2nd filer along with it's 2 shelves.
Power down the shelf 1 on the first F740 filer.
connect shelf 0 to the filer on both slots 6 & 7? using the input pors ? I don't have terminators unfortunately. And then start the OS installation ?
wstroh
Close. You'll only want one set of cables going to the FC shelves. You can hook up a secondary path (i.e. the shelves would be connected via both slots 6 and 7) however for purposes of simplifying the loop, let's just use one connection for the time being.
As far as powering down things are concerned, I would recommend powering down both heads and all shelves involved before cabling them up. This will allow for a "cleaner" startup.
johnchang
Ok,
so if I'm using only one shelf (shelf 0) and one filer, what should the cable connection look like?
Do, I take the FC cable put it in slot 7 of the filer and put the db9 end to the input port of shelf 0 and if so, which side as you know FC9 shelfs have two VEMs. Is that all I need to start installing the new os ?
wstroh
Yeup.
The DB9 should be connected to the left port (the in port) of the leftmost VEM module if you're looking at it from the back of the shelf. Page 27 of the FC9 guide located here:
http://now.netapp.com/NOW/knowledge/docs/hardware/filer/fcshf92.pdf
shows the setup for multiple FC9 shelves. It will be the same for your setup, just with a single shelf. Then you should be able to floppy boot 6.3 and start the install.
Now, the caveat.
If you still experience loop instability I would try the following:
- Power down the system (shelves and filer)
- remove the 'B' module VEM (the VEM on the right side of the shelf) and swap it with the 'A' module
- Power the system back up
This will let you rule out the module.
If you still have instability, power everything down again and try a different cable.
Next, you would try a different adapter.
Finally, as you only need 2 disks for ONTAP to install (a parity and a data), you would remove every disk from the shelf except for the ones in bays 3 and 4 (count from the right of the shelf starting at bay 0). 3 and 4 are the scsi enclosure services bays for the FC9 shelves, so those are required for the loop to work properly.
johnchang
Ok,
So, I tried installing v6.1R1 using only the shelf 0 and it did not work - see attachment.
Then I tried only disks 3 & 4 with v6.3. This time it let me into the special menu where I selected option 4 and it also complained, see attachment: v6.3 OS install test.text.
Perhaps the disks are bad?
wstroh
Tue Aug 19 19:55:36 GMT [net_e0:info]: Ethernet e0: Link up.
Tue Aug 19 19:55:44 GMT [ispfc_init_2:warning]: Resetting Fibre Channel adapter 7.
Tue Aug 19 19:55:58 GMT [scsi.cmd.pastTimeToLive:error]: Device 7.4: request failed after retry #0: cdb 0x1b.
ispfc: 11 loop-initialization events seen in 60 seconds on Fibre Channel adapter 7: indicates loop stability problem.
Tue Aug 19 19:56:43 GMT [ses_admin:error]: Disk 7.4 not detected by Enclosure Services.
Tue Aug 19 19:56:57 GMT [ispfc_init_2:warning]: Resetting Fibre Channel adapter 7.
ispfc: 10 loop-initialization events seen in 60 seconds on Fibre Channel adapter 7: indicates loop stability problem.
Tue Aug 19 19:57:17 GMT [ispfc_init_2:warning]: Resetting Fibre Channel adapter 7.
Tue Aug 19 19:57:36 GMT [scsi.cmd.pastTimeToLive:error]: Device 7.4: request failed after retry #0: cdb 0x1b.
ispfc: 9 loop-initialization events seen in 60 seconds on Fibre Channel adapter 7: indicates loop stability problem.
Tue Aug 19 19:58:21 GMT [ses_admin:error]: Disk 7.4 not detected by Enclosure Services.
Tue Aug 19 19:58:21 GMT [ses_admin:error]: No possible actual addresses found.
7.4 was chatty earlier as well. pull that disk and put it off to the side and let's replace him with someone else, then powercycle everything and try the boot again. If you encounter the same (or close) results, try hooking up a different shelf as shelf0. or you could try the adapter in slot 6. Unfortunately at this point, it's a lot of plug 'n chug to get results that the system is happy with.
johnchang
Hi, ok so as you know my first 2 attempts didn't work so this time, what I did you use the full shelf loaded with all the disks and used the install floppies for v6.3 and it looked really good:
Got to hte special menu and option 4 worked, to initialize the disks which it did.
Then it gave me the setup menu to set the hostname, ip address etc..... etc..... then at the end it told me to reboot to use the new settings so I did.
But in the end it did work because of this error:
Alpha Open Firmware by FirmWorks
Copyright 1995-2000 FirmWorks, Network Appliance. All Rights Reserved.
Firmware release 2.8_a2
Memory size is 512 MB
Testing SIO
Testing LCD
Probing devices
Testing 512MB
16MB chunks
1 to 16MB
16 to 32MB
32 to 48MB
48 to 64MB
64 to 80MB
80 to 96MB
96 to 112MB
112 to 128MB
128 to 144MB
144 to 160MB
160 to 176MB
176 to 192MB
192 to 208MB
208 to 224MB
224 to 240MB
240 to 256MB
256 to 272MB
272 to 288MB
288 to 304MB
304 to 320MB
320 to 336MB
336 to 352MB
352 to 368MB
368 to 384MB
384 to 400MB
400 to 416MB
416 to 432MB
432 to 448MB
448 to 464MB
464 to 480MB
480 to 496MB
496 to 512MB
Complete
Finding image...
Loading scsi-disk
Can't open boot device
Startup failed
I've attached the logs, not sure what went wrong but this is the furthest I've gotten thus far.
Thank you very much!!!!!!!!!!!!!!!!!!!!!!!!
REALLY REALLY appreciate your help with this.
wstroh
Hey John!
Alrighty, we're on the home stretch. Ran into the same problem many many times back in the day and it's an easy fix 🙂
What you've done is booted off of floppies. This loads the kernel into memory, but it hasn't been written anywhere. What you'll want to do is once setup has completed, grab the 6.3 system files from the NOW site:
(I'm actually giving you the link to 6.3.3, as that was the best release in the 6.3 family)
http://now.netapp.com/NOW/download/software/ontap/6.3.3/
Scroll to the bottom of that page and click 'continue', then click through the EULA and finally grab the System Files depending on if you're doing the install from Unix (49mb file) or Windows (39mb file)
Follow the install instructions for that here:
http://now.netapp.com/NOW/knowledge/docs/ontap/rel633/html/ontap/upgrade/index.htm
The key point here is you *must* issue a 'download' as this will copy the kernel to the boot blocks, allowing the filer to boot next time without using the boot floppies.
On the home stretch John! 🙂
johnchang
Will,
Thanks so much for you guidance.
Few more questions before I start the system file installation. I will be using my laptop that is running windows.
1. Do I need to boot of the floppies again to start this procedure as we have no working OS on the filer ?
2. After running the setup off the floppies, will I be able to connect to the filer_ipaddress:/etc from my windows ?
3. So, I just double click the 633_setup_a.exe file and that is it?
My BIG question is how do I do these:
Step
Action
1
Log in to your client as Administrator or an account that has full control on the filer C$ share.
2
Map a drive to the C$ directory of your filer according to the procedure for your version of Windows.
once again thanks soooooooooooooo much Will.....
wstroh
Hi John!
Yes. Right now we have no boot blocks, so you'll need to use them one more time going into this final operation.
Sort of. After setup you'll have to setup cifs. This is very infrastructure specific, so the instructions I'm including below are for setting it up in the most generalized sense. I ran through it on my 960 and it worked, so it's had at least a bit of sanity checking 🙂
A bit more intensive than that I'm afraid,
Once the basic setup has completed (hostname, IP address, etc), you'll need to license CIFS and run 'cifs setup'. The install I ran was under 7.2.4, but it should be relatively similar (it hasn't changed much in the six years I've been using it). In step 2 below, I choose 'workgroup mode' when choosing authentication. This is going to be infrastructure dependent to your site. Choosing 'workgroup' will allow you to use the rest of the flow below to install the system files off of your laptop. For now, I would recommend going that route as you can always change it later by rerunning 'cifs setup'.
1) License cifs.
filer> license cifs=abcdefghi
A cifs license has been installed.
filer> Wed Aug 20 12:43:14 EDT [filer: rc:notice]: cifs licensed
filer>
2) Run cifs setup to enable cifs.
filer> cifs setup
This process will enable CIFS access to the filer from a Windows(R) system.
Use "?" for help at any prompt and Ctrl-C to exit without committing changes.
Your filer does not have WINS configured and is visible only to
clients on the same subnet.
Do you want to make the system visible via WINS? [n]:
This filer is currently configured as a multiprotocol filer.
Would you like to reconfigure this filer to be an NTFS-only filer? [n]:
The default name for this CIFS server is 'filer'.
Would you like to change this name? [n]:
Data ONTAP CIFS services support four styles of user authentication.
Choose the one from the list below that best suits your situation.
(1) Active Directory domain authentication (Active Directory domains only)
(2) Windows NT 4 domain authentication (Windows NT or Active Directory domains)
(3) Windows Workgroup authentication using the filer's local user accounts
(4) /etc/passwd and/or NIS/LDAP authentication
Selection (1-4)? [1]: 3
What is the name of the Workgroup? [WORKGROUP]:
CIFS - Starting SMB protocol...
Welcome to the WORKGROUP Windows(R) workgroup
CIFS local server is running.
filer>
filer> Wed Aug 20 12:46:03 EDT [filer: nbt.nbns.registrationComplete:info]: NBT: All CIFS name registrations have completed for the local server.
3) Verify that a share has been created for C$
filer> cifs shares
Name Mount Point Description
ETC$ /etc Remote Administration
BUILTIN\Administrators / Full Control
HOME /vol/vol0/home Default Share
everyone / Full Control
C$ / Remote Administration
filer>
4) Map to a *drive letter* on your Windows machine using 'administrator' as your username and root's password as the 'password'
5) Verify via the net use command
Y:\>net use
New connections will not be remembered.
Status Local Remote Network
OK Y: \\192.168.75.10\C$ Microsoft Windows Network
6) Install system files
Double click on the 6.3.3 setup.exe file
This will bring up a WinZip self-extractor box stating that you'll need to have C$ mapped as administrator.
Click 'ok'
It will prompt you with <drive>:\etc
Replace <drive> with the drive letter you mapped C$ to. In the example above, I replace it with 'Y' so the box will read:
Unzip to folder: Y:\etc
This will unzip the system files to the /etc directory of the filer. Upon completion it may ask you if you wish to run inst_perm.bat. Click 'yes' (this will set the correct permissions on the files in /etc should they have been overwritten.
Once this operation has completed (takes roughly a minute), log into the filer and issue 'download'. This will load the boot blocks on the FCAL disks with the kernel.
filer> download
download: Reminder: upgrade both the nodes in the Cluster
download: You can cancel this operation by hitting Ctrl-C in the next 6 seconds.
download: Depending on system load, it may take many minutes
download: to complete this operation. Until it finishes, you will
download: not be able to use the console.
Wed Aug 20 12:53:47 EDT [filer: download.request:notice]: Operator requested download initiated
download: Downloading boot device
download: Downloading boot device (Service Area)
download: Downloading disks: .....done
download: boot blocks successfully copied to disk(s)
filer> Wed Aug 20 12:58:40 EDT [filer: download.requestDone:notice]: Operator requested download completed
7) Reboot
Once the above is complete, it is safe to reboot the filer
filer> reboot
The filer should boot back up running 6.3.3.
johnchang
Will,
Thaks for such detailed procedure but here is one problem that keeps me from moving forward. Just like yesterday, I booted from the floppies and then setup the filer as below:
netapp1toc> setup
NetApp Release 6.3: Wed Aug 7 23:04:57 PDT 2002
System ID: 0016807404 (netapp1toc); partner ID: 0016807718 ()
slot 0: System Board
Processors: 1
Memory Size: 512 MB
slot 0: Fibre Channel Host Adapter 0a
slot 0: SCSI Host Adapter 0b
slot 0: Ethernet Controller e0
MAC Address: 00:a0:98:00:94:c8 (auto-100tx-fd-up)
slot 3: FastEnet-10/100 Quad Ethernet Controller
e3a MAC Address: 00:20:fc:1e:5d:30 (auto-unknown-cfg_down)
e3b MAC Address: 00:20:fc:1e:5d:31 (auto-unknown-cfg_down)
e3c MAC Address: 00:20:fc:1e:5d:32 (auto-unknown-cfg_down)
e3d MAC Address: 00:20:fc:1e:5d:33 (auto-unknown-cfg_down)
slot 6: Fibre Channel Host Adapter 6
7 Disks: 241.5GB
1 shelf with VEM
slot 7: Fibre Channel Host Adapter 7
slot 8: Interconnect adapter
slot 9: NVRAM
Memory Size: 32 MB
Please enter the new hostname [netapp1toc]:
Do you want to configure virtual network interfaces? [n]: y
Number of virtual interfaces to configure? [0] 1
Name of virtual interface #1 []: vif1
Is vif1 a single [s] or multi [m] virtual interface? [m] s
Number of links for vif1? [0] 4
Name of link #1 for vif1 []: e3a
Name of link #2 for vif1 []: e3b
Name of link #3 for vif1 []: e3c
Name of link #4 for vif1 []: e3d
Please enter the IP address for Network Interface vif1 []: 57.4.26.209
Please enter the netmask for Network Interface vif1 [255.0.0.0]: 255.255.255.0
Should virtual interface vif1 take over a partner virtual interface during failover? [n]: n
Please enter media type for vif1 {100tx-fd, tp-fd, 100tx, tp, auto} auto:
Please enter the IP address for Network Interface e0 []: 10.3.26.209
Please enter the netmask for Network Interface e0 [255.0.0.0]: 255.255.255.0
Should interface e0 take over a partner IP address during failover? [n]:
Please enter media type for e0 {100tx-fd, tp-fd, 100tx, tp, auto} auto:
Would you like to continue setup through the web interface? [n]:
Please enter the name or IP address of the default gateway: 57.4.26.1
The administration host is given root access to the filer's
/etc files for system administration. To allow /etc root access
to all NFS clients enter RETURN below.
Please enter the name or IP address of the administration host: 57.4.26.221
Where is the filer located? []: P3_testbed
Do you want to run DNS resolver? [n]:
Do you want to run NIS client? [n]:
The root volume currently contains 2 disks; you may add more
disks to it later using the "vol add" command.
Now type 'reboot' for changes to take effect.
So, I reboot but then I can't access this filer through either the e0 interface or the vif1 interface
Question: Do the ip interfaces become available immediately AFTER the setup has been finished or does the filer need a reboot ?
I think once I can ping/mount /vol/vol0 , I should be able to move on but I'm stuck here.
wstroh
Hey John!
Yeah, you don't want to reboot yet. Those changes have taken effect, but only in memory. You should be able to ping/mount at this point in the game, and be able to carry out the rest of the procedure.
johnchang
I see,ok then I guess I'll have to boot from the floppis again. any hoots, it looks like using the linux nfs is going to be easier.
Did my setup look correct? As I was not able to ping the filer.
johnchang
I have tried to enable CIFS not it looks like it didn't work. How can I enable NFS so i can mount /vol/vol0 to the local unix server and then execute the script that way? I can telnet into the system from the admin host and my exportfs looks like this:
/vol/vol0/home -root=10.3.26.230
/vol/vol0 -access=10.3.26.230,root=10.3.26.230
This is what the options look like:
auditlog.enable on
auditlog.max_file_size 10000000
autologout.console.enable on
autologout.console.timeout 60
autologout.telnet.enable on
autologout.telnet.timeout 60
autosupport.cifs.verbose off
autosupport.content complete
autosupport.dafs.verbose off
autosupport.doit DONT
autosupport.enable on
autosupport.from postmaster
autosupport.mailhost mailhost
autosupport.noteto
autosupport.retry.count 15
autosupport.retry.interval 4m
autosupport.support.enable on
autosupport.support.proxy
autosupport.support.to autosupport@netapp.com
autosupport.support.transport http
autosupport.support.url support.netapp.com/asupprod/post/1.0/postAsup
autosupport.throttle on
autosupport.to
backup.log.enable on
cf.takeover.on_failure on
cf.takeover.on_panic off
cifs.audit.enable off
cifs.audit.file_access_events.enable on
cifs.audit.logon_events.enable on
cifs.audit.logsize 524288
cifs.audit.saveas /etc/log/adtlog.evt
cifs.bypass_traverse_checking on
cifs.comment
cifs.guest_account
cifs.home_dir
cifs.home_dir_namestyle
cifs.idle_timeout 1800
cifs.max_mpx 50
cifs.netbios_aliases
cifs.netbios_over_tcp.enable on
cifs.nfs_root_ignore_acl off
cifs.oplocks.enable on
cifs.oplocks.opendelta 8
cifs.per_client_stats.enable off
cifs.perm_check_ro_del_ok off
cifs.perm_check_use_gid on
cifs.restrict_anonymous.enable off
cifs.save_case on
cifs.scopeid
cifs.search_domains
cifs.show_snapshot off
cifs.shutdown_msg_level 2
cifs.sidcache.enable on
cifs.sidcache.lifetime 1440
cifs.snapshot_file_folding.enable off
cifs.symlinks.cycleguard on
cifs.symlinks.enable on
cifs.trace_login off
cksum_offload.gbeII off
console.encoding nfs
coredump.cf.dump_partner_nvram off
dafs.auth_none.enable off
dafs.checksums.enable off
dafs.default_gid 100
dafs.default_uid 100
dafs.enable off
dafs.idle_timeout 7200
dafs.max_disconnected_sessions 32
dafs.max_pending_requests_server 512
dafs.max_request_size 69632
dafs.max_requests 50
dafs.max_requests_server 1024
dafs.max_response_size 69632
dafs.num_requestd 2
dns.domainname
dns.enable off
fcp.enable off
httpd.access legacy
httpd.admin.access legacy
httpd.admin.enable on
httpd.autoindex.enable on
httpd.enable off
httpd.log.format common
httpd.log.max_file_size 2147483647
httpd.rootdir XXX
httpd.timeout 300
httpd.timewait.enable off
ip.fastpath.enable on
ip.match_any_ifaddr on
ip.path_mtu_discovery.enable on
ip.tcp.sack.enable on
iscsi.enable off
locking.grace_lease_seconds 45
ndmpd.preferred_interface disable
nfs.mount_rootonly on
nfs.per_client_stats.enable off
nfs.require_valid_mapped_uid off
nfs.tcp.enable on
nfs.udp.xfersize 32768
nfs.v2.df_2gb_lim off
nfs.v3.enable on
nfs.webnfs.enable off
nfs.webnfs.rootdir XXX
nfs.webnfs.rootdir.set off
nis.domainname
nis.enable off
nis.group_update.enable off
nis.group_update_schedule 24
nis.servers *
pcnfsd.enable off
pcnfsd.umask 22
raid.reconstruct.perf_impact medium
raid.resync.perf_impact medium
raid.scrub.duration 360
raid.scrub.enable on
raid.scrub.perf_impact low
raid.timeout 24
raid.verify.perf_impact low
rmc.setup off
rsh.access legacy
rsh.enable on
security.passwd.rules.enable on
snapmirror.access legacy
snapmirror.checkip.enable off
snapmirror.delayed_acks.enable on
snapmirror.enable off
snapmirror.log.enable on
snapvault.access none
snapvault.enable off
snmp.access legacy
snmp.enable off
tape.persistent_reservations off
telnet.access legacy
telnet.enable on
tftpd.enable off
tftpd.logging off
tftpd.rootdir /etc/tftpboot
timed.enable off
timed.log off
timed.max_skew 30m
timed.min_skew 50
timed.proto ntp
timed.sched hourly
timed.servers
trusted.hosts *
vol.copy.throttle 10
wafl.default_nt_user
wafl.default_security_style unix
wafl.default_unix_user pcuser
wafl.nt_admin_priv_map_to_root on
wafl.root_only_chown on
wafl.wcc_minutes_valid 20
Do I need to enable NFS and if so where or how can I get the license?
netapp1toc> license nfs=ABCDEFGHI
invalid service -- nfs not licensed
We are close, please get me over the hump.....
wstroh
You can do it over NFS as well (you'd need to download the 6.3.3 tarball instead) if you'd like. 'ABCDEFGHI' is not a valid license code - it's simply one I'm using for purposes of example. You'd need to use whatever license codes you have for the 740.
johnchang
So I can just use the NFS license from my production Fas270 for installation purposes? Wouldn't I need this license for later when I want to use it to exports the filesystems ?
I actually got the opportunity to talk to a tech from netapp and he told me I can use ftp to transfer the file but when I went to do "options ftp" I didn't see this option.
Any thoughts? oh I did see tftp though....
johnchang
Will,
It looks like the filer finally works now, thank you for all your hard work but I still have some questions left over.
1. The web filerview tells me I'm only using 2 disks, whata do I need to do to get the filer to see ALL the disks on the shelf.
2. How do I add the second shelf ?
Once again, you have been a life saver.....
wstroh
Hi John -
Glad to hear you're up and running. To add the rest of the disks (I assume they are spares) you would simply issue a 'vol add <volname> <number of disks>'. For example, if you have five other disks on the shelf, if you issue 'vol add vol0 5' it will add the other five disks.
You can see the state of the disks (spares or otherwise) by issuing a 'vol status -r'.
While you can add the other shelf hot, I would recommend powering down the system, cabling up the second shelf (using the out port of the VEM on shelf 1 cabled to the in port on the VEM of shelf2), set the shelf id of the second shelf, and then power on both shelves, wait approx 30 seconds, and power on the head.
johnchang
Ok, when I got in this morning, I noticed that I could no longer access the filer. So, when I went to physically see the filer,it said " A disk has failed" and netapp did not fully boot.
I took the laptop and captured some info:
RAID Disk Device HA SHELF BAY CHAN Used (MB/blks) Phys (MB/blks)
parity FAILED N/A 34500/70656000
data FAILED N/A 34500/70656000
data 6.6 6 0 6 FC:A 34500/70656000 35003/71687368
this doesn't look good.
I've also attached rest of the log.
