Network and Storage Protocols
Compare Netapp and SUN
daniel_wasyl
Hello
want to let sun compare to the NetApp if you can give me the performance data for NFS
4 REPLIES 4
amiller_1
Hmm....can you provide more details of what specifically you're looking for?
daniel_wasyl
The question is simple. Why NetApp is better than Sun-a. published by NetApp NFS tests are far from ideal normal operation of the system.
amiller_1
Some food for thought here at least...
http://blogs.netapp.com/eislers_nfs_blog/2009/02/chuckle-for-tod.html
To be honest, I'm not sure you'll find a lot of people here intimately familiar with the current Sun storage lineup (was my first guess and also seems that way given the lack of response 😕 ).
radek_kubka
The word of the street is SUN simply doesn't deliver - both in the terms of reliability and performance.
I've heard that many times from many sources (including actual SUN customers), so have a right to believe that they are far from being Enterprise-level product.
Regards,
Radek
