Network and Storage Protocols
Copy a NetApp volume to 3PAR
RAJMEHTA1
I would like to copy/migrate a NetApp volume to HP 3PAR.  What is the best way to do this with the least down time if at all?
1 ACCEPTED SOLUTION
radek_kubka
You present LUNs from both storage systems to the same host & use something like robocopy or xcopy to to move the content.
On the SQL side you detach database from the old LUN & attach it from the new LUN.
The main gotcha is to properly copy Windows ACLs, but this can be sorted using right switches with robocopy / xcopy.
4 REPLIES 4
radek_kubka
What kind of data are we talking about?
Your most likely bet, is to look at host-based migration.
RAJMEHTA1
I have a bunch of volumes with SQL databases being hosted.  How do I go about doing host-based migration?
radek_kubka
RAJMEHTA1
That works!  Thanks.
