Network and Storage Protocols
Delete Qtree - Not Empty
jasonnash
Hi All,
I have some qtrees full with CIFS data I need to delete, I cannot do so as thet are not empty. It will take sometime to delete all of the CIFS data due to not having NTFS permissions and ownership over the folder/files. I don't really want to have to take ownership and mess with permissions in order to delete the qtrees.
Surely there is a way to force the deletion of the qtree, I did see some one mentions the priv set advanced commands but I want to be sure rather than just attempting commands as this is a live filer.
Can someone assist?
Jason
1 ACCEPTED SOLUTION
jasonnash
I did it in the end, I used the following commands. It sits there for a while deleting but it does the trick.
priv set advanced
qtree delete -f /vol/volume/qtree
3 REPLIES 3
rwelshman
What command are you using to try the delete? What is the error message?
jasonnash
priv set advanced
ROGIERBURLAGE
Thanks, m8. I was already wondering. Why would you have a command like qtree create /vol/volume/qtree but there is no qtree delete /vol/volume/qtree
But then I compared qtree help under normal prompt and then in privilege advanced mode and understood that NetApp thinks that that command to be a bit risky and I understand the privilege mode a little bit better again.
