Network and Storage Protocols
Great difference in space allocation between EMC and Netapp
baszom
Hi,
we copied by rsync a volume containing MANY MANY files (28,819,704) from an old EMC Celerra array to a Netapp FA8060.
On source, I have about 2 TB of data that, with deduplication on, become 1.4 TB.
On destination, I'm already at 1.9 TB and rsync still doesnt' end, in spite of deduplication and compression saving of about same percentual of EMC.
How is it possible? Is there some basic difference of block size?
Thanks
2 REPLIES 2
georgevj
File based copying programs are not necessarily deduplication-aware. You may have to run dedupe once after the copying is complete, unless you have enabled automatic schedules.
from TR-3958: (http://www.netapp.com/us/media/tr-3958.pdf)
Compression and deduplication share the same scheduler and can be scheduled to run in one of five
different ways:
 Inline (compression only)
 Scheduled on specific days and at specific times
 Manually, by using the command line
 Automatically, when 20% new data has been written to the volume
 SnapVault software based, when used on a SnapVault destination
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
mimmus
Solved: there was +800 GB of snapshot copies forgotten after disabling snapshot reserve 😞
