Network and Storage Protocols
How to get FPolicy connection time via C/C++ SDK ?
volkevolke
Hello everyone,
is it possible to get the time elapsed a server is connected to an FPolicy via the C/C++ API?
In the console one can see the information in the "fpolicy" command output under Connect time (here 00:05:57)
File screen servers            P/S Connect time (dd:hh:mm)  Reqs Fails
172.20.73.50 \\Test-FPolicy  Pri 00:05:57        1567289    0
ServerID: 218    IDL Version: 1 SMB Request Pipe Name: \ntapfprq
    Options enabled: async
I would like to get this information via the NetApp Managebility SDK.
I didn't find any API-Call which delivers this information.
For me that would belong to the server-info structure (to be retrieved via the API-call fpolicy-server-list-info)
but unfortunately there is no such value.
May be I've just missed the info in the SDK-Docs (SDK Version 5.2.1R1) or is querying for the connection time simply not possible?
Thanks in advance.
Martin
3 REPLIES 3
ekashpureff
Martin -
Looking through the API in ZExplore...
API: fpolicy-server-status-get-iter
    Element: desired-attributes
        Element: fpolicy-server-status-info
            Element: connected-since
I hope this response has been helpful to you.
At your service,
Eugene E. Kashpureff, Sr.
Independent NetApp Consultant, K&H Research http://www.linkedin.com/in/eugenekashpureff
Senior NetApp Instructor, IT Learning Solutions http://sg.itls.asia/netapp
(P.S. I appreciate points for helpful or correct answers.)
volkevolke
Hello Eugene,
thank you for your prompt answer.
Unfortunately the api call fpolicy-server-status-get-iter
seems to be available only for vfilers. (that we don't have in usage)
When I do the call on our FAS3240 (8.0.5 7-Mode) I'll get
  errno: 13005   reason: Unable to find API: fpolicy-server-status-get-iter
But thanks a lot for mentioning ZExplore ... I wasn't aware of 🙂
Best Regards,
Martin
ekashpureff
Martin -
You're very welcome.
Yes, fpolicy-server-status-get-iter is a cluster mode API call.
Glad you got Zexplore out of it.
It's a very powerful tool.
Enjoy !
I hope this response has been helpful to you...
At your service,
