Network and Storage Protocols
Is it necessary to add in additional drives for upgrade to a dual controller?
SEBASTIANSIM
Hi,
Currently i have the following set up and would like to add in 2nd controller for all the below existing SAN storage.
S/N
Machine   Type
Raw   Disk Capacity
Disk   Space
[Total Usable]
1
NetApp   FAS2040
12   x 1TB SATA
6.55TB
2
NetApp   FAS2020
12   x 500GB SATA
3.27   TB
3
NetApp   FAS2020
12   x 500GB SATA
3.27   TB
4
NetApp   FAS2020
12   x 500GB SATA
3.27   TB
5
NetApp   FAS2020
6   x 500GB SATA
1.09   TB
I need your advice on the following;
1) Do i need to add in 3 extra drives for the upgrade of a single controller to a dual-controller configuration?
2) By adding in 3 extra drives for the upgrade of single controller to a dual controller; is the best practice to construct the minimum RAID group?
Many thanks
1 ACCEPTED SOLUTION
nigelg1965
I think the answer is going to be yes, unless you have several spare disks (min 3 or 4) per filer, or can can move or delete a aggregate.
Why so many small filers, are they seperate sites?
May be you could buy a single external shelf and fail half the disks of each filer over one at a time.
2 REPLIES 2
nigelg1965
SEBASTIANSIM
Hi,
Yes there are many sites. Many thanks for your help. Really appreciate it.
