Network and Storage Protocols
LDAP Configuration Problem
JOSHBAIRD
Hi,
I'm attempting to configure LDAP on v8.0.1P4.  This Filer is already joined to a domain using "cifssetup," but I need to configure LDAP to read from our Active Directory for NFS purposes.  Here is my LDAP config:
ldap.ADdomain                na.domain.lan
ldap.base                    dc=na,dc=domain,dc=lan
ldap.base.group              dc=na,dc=domain,dc=lan
ldap.base.netgroup
ldap.base.passwd             dc=na,dc=domain,dc=lan
ldap.enable                  on
ldap.minimum_bind_level      simple
ldap.name                    CN=NetAppServiceAccount,OU=CRP,OU=Administration,DC=na,DC=domain,DC=lan
ldap.nssmap.attribute.gecos  name
ldap.nssmap.attribute.gidNumber gidNumber
ldap.nssmap.attribute.groupname cn
ldap.nssmap.attribute.homeDirectory homeDirectory
ldap.nssmap.attribute.loginShell loginShell
ldap.nssmap.attribute.memberNisNetgroup memberNisNetgroup
ldap.nssmap.attribute.memberUid memberUid
ldap.nssmap.attribute.netgroupname cn
ldap.nssmap.attribute.nisNetgroupTriple nisNetgroupTriple
ldap.nssmap.attribute.uid    uid
ldap.nssmap.attribute.uidNumber uidNumber
ldap.nssmap.attribute.userPassword userPassword
ldap.nssmap.objectClass.nisNetgroup nisNetgroup
ldap.nssmap.objectClass.posixAccount posixAccount
ldap.nssmap.objectClass.posixGroup posixGroup
ldap.passwd                  ******
ldap.port                    389
ldap.servers
ldap.servers.preferred
ldap.ssl.enable              off
ldap.timeout                 20
ldap.usermap.attribute.unixaccount sAMAccountName
ldap.usermap.attribute.windowsaccount sAMAccountName
ldap.usermap.base
ldap.usermap.enable          off
I have verified using "wcc -u domainusername" that the LDAP connection is not working.  I also tried to use getXXbyYY:
filer*> wcc -u jbaird
no passwd entry for jbaird
filer*> getXXbyYY getpwbyname_r jbaird
Could not get passwd entry for name = jbaird
My nsswitch.conf contains "files ldap" for passwd and for groups.
I don't see anything interesting in /etc/messages.  What is the next step to debug this problem?
Thanks!
6 REPLIES 6
JOSHBAIRD
Ok, after taking packet captures, I believe the Filer is constructing the LDAP query incorrectly.  This is how it is attempting to filter the LDAP results:
Filter: (&(objectClass=sAMAccountName)(uid=jbaird))
It should be using a filter like this:
(&(objectClass=user)(sAMAccountName=jbaird))
But, I cannot figure out how to change this filter from the ldap options/commands that are available.  Can anyone help?
Thanks.
JOSHBAIRD
Ok, I figured this out:
ldap.nssmap.attribute.uid    user
ldap.nssmap.objectClass.posixAccount sAMAccountName
According to the newest packet capture after making these changes, the LDAP server is returning a successful query result!  The user is found, but the Filer is still saying "no passwd entry for jbaird":
aborzenkov
You have to explicitly maintain plain text passwords for users in AD. There is no way to reconstruct it from native AD data. IIRC there were utilities to do it.
Is using Kerberos an option? This would eliminate need to use and maintain plain text passwords.
JOSHBAIRD
Where is this documented?  The documentation and other posts on the forum lead me to believe that this is not the case.  The Filer should be able to enumerate users from external NIS and LDAP sources from what I have read.  What would be the point of configuring the Filer to read from an LDAP directory if it cannot even enumerate user information from the LDAP/NIS directory?
aborzenkov
Your filer does find user in LDAP, does not it?
User information does not magically appear in LDAP all by itself. Someone has to enter it there. Windows AD is never using plain text passwords so it is never entered in AD.
JOSHBAIRD
No, I cannot get the Filer to enumerate any data from AD, even though when I look at a packet capture during a "wcc -u username," I see a successful LDAP query and response.  Support has lead me to this doc:
https://kb.netapp.com/support/index?page=content&id=1010909&actp=search&viewlocale=en_US&searchid=1354073465185
However, this is exactly how I already had it configured.  "wcc -u username" still returns "no passwd entry for username."
