Network and Storage Protocols
Location for fpolicy logs
NETAPPNAVEEN
I followed the tr-3595 Document which is "File Access Auditing on NetApp Controller" by Sharyathi Nagesh, Reena Gupta, NetApp
I was able to set the fpolicy simulator successfully using the instructions but in the final step it say the following:
EVENT FORMAT
Notifications are generated in a NetApp proprietary format. This is explained in more detail in the FPolicy SDK.
ACCESSING THE EVENT LOGS
The NetApp FPolicy framework provides two interfaces to manage FPolicy on the controller:
• ONTAPI® calls, which are used to set policy-related options; all operations that can be performed on the NetApp console can be performed through ONTAPIs
• DC-RPC calls, which are used by the FPolicy server to perform advanced operations such as registering to the policy, receiving notifications, and responding to notifications
Can anyone please tell me how I can get the fpolicy logs or have it registered with any of my client. Appreciate all your help!!
Thanks,
Naveen
1 REPLY 1
NETAPPNAVEEN
Also where can I find the Fpolicy SDK.
I do not see any such thing.
Naveen
