Network and Storage Protocols
Logging/Auditing changes to CIFS shares (add, del, modify, etc)
GARDINEC_EBRD
HI All,
Sorry, I can't help feeling I should know this, but I just can't find what I'm looking for.  We have a number of vfilers providing CIFS file sharing.  We have a team of 1st line support people who have rights to create, remove and modify shares via the Windows MMC.  I'd like to be able to keep a log of these changes, but I can't seem to find out how/where to do this.  I've turned on CIFS audit logging, but only seem to see login/logout events.  I've turned on the option cifs.audit.account_mgmt_events.enable, but it doesn't seem to have changed what is logged in the event logs.
Anyone have any clues on this?
Thanks,
Craig
5 REPLIES 5
scottgelb
Since an ontap command or API, do you see it on the auditlog file?
GARDINEC_EBRD
Hi Scott,
Thanks for your reply.  Do you mean /etc/log/auditlog?  If so, yeah, I checked in there, but didn't see anything relating to the change to the CIFS share either.
Craig
scottgelb
Yes… thank you. Does it show in the vfiler /etc/log/auditlog root volume or are you checking vfiler0? I’ll have to test it out too
GARDINEC_EBRD
Ah...yes, should have been more specific, sorry.  This is in the /etc/log dir of the physical filer (vfiler0).  The vfiler's /etc/log dir only contains the *.alf and *.evt files
sgrant
Hi Craig, a bit late to the party and hope you've already found the answer, if not then I believe your problem maybe that you need to enable the events to be logged...
This can be completed either via:
  • The Auditing feature under the Windows Explorer Security tab being enabled within the Windows file system.
  • Or, using the fsecurity command, but this is at a storage level outside of Windows that can also be applied to the volume or qtree.
Just remember: "Be sure to select only the events that must be audited because selecting too many audit options might affect system performance."
A good TR on the subject is TR-3595 (http://www.netapp.com/us/media/tr-3595.pdf)
Hope that helps.
Cheers,
Grant.
