Network and Storage Protocols
Max open files
poisse_eric
Is there anybody who knows the maximum number of open files on a fas3020 ?
We use a PLM software (Smarteam) which stores files on our FAS3020, and we noticed that a user can open more than 400 files ! (just open, but not really used). I'm just a little bit worried, because we have 40 PLM users.
Regards
3 REPLIES 3
radek_kubka
Hi & welcome to the forums!
I've never came across a number of open files being an issue & don't think it could give you any trouble.
Have a look at this thread re max files (stored on a filer):
http://communities.netapp.com/message/4605#4605
Regards,
Radek
pascalduk
CIFS resource limits:
http://now.netapp.com/NOW/knowledge/docs/ontap/rel732_vs/html/ontap/filesag/GUID-38C0F43B-B9C6-411E-8E48-7CB875BEFDD0.html
But with only 40 users which each have 400 open files should not be a problem at all.
poisse_eric
Thanks a lot !
