Network and Storage Protocols
Modifying NFS Exports on existing volume -for ESX
txskibum2000
I need to modify export permissions to several volumes on my 7-mode cluster.  I normally use OnCommand System Manager, but I have several volumes to modify and it would take a while to go through each one..  Another option I am aware of to modify the exports file in \etc.  However, when I modify the exports file, the change does not reflect in System Manager or Filerview.  What gives?  Is there somewhere else I need to modify or command to issue? Thanks.
1 ACCEPTED SOLUTION
billshaffer
Assuming you exportfs -r after modifying /etc/exports, the gui tools probably have to refresh to see the new data.  Do they not update, even after a while?
Bill
3 REPLIES 3
billshaffer
Bill
txskibum2000
I completely forgot about exportfs -r
billshaffer
