Network and Storage Protocols
Mounting NFS volume in Netapp Simulator
natrian_maxwell
Hello,
I seem to be having a connection issue with my Netapp simulator. For example,
I can ping the Storage system from my Admin host
Nates-MacBook-Pro:/ betterplace$ ping NetappPING netapp.hsd1.ca.comcast.net (208.67.216.145): 56 data bytes
64 bytes from 208.67.216.145: icmp_seq=0 ttl=51 time=36.699 ms
64 bytes from 208.67.216.145: icmp_seq=1 ttl=51 time=37.365 ms
64 bytes from 208.67.216.145: icmp_seq=2 ttl=51 time=39.880 ms
^C
I can ping my admin host from the storage simulator
Netapp> ping 192.168.0.10
192.168.0.10 is alive
Telnet hangs and timesout
Nates-MacBook-Pro:/ betterplace$ telnet Netapp
Trying 208.67.216.145...
ssh returns an error message
Nates-MacBook-Pro:/ betterplace$ ssh Netapp
ssh: connect to host Netapp port 22: Connection refused
Both ssh v1 and v2 are enabled and the keys have been generated.
I think because of this error, I am not able to mount any of the exported volumes on my admin host. Can anyone offer any advice?
Thanks
1 ACCEPTED SOLUTION
reide
Natrian,
Which version of the sumulator 7.x or 8.x?
You didn't specify if the simulator was running in a VM, but I'm assuming it is. The fact that you can successfully ping bi-directionally between the sim and your MacBook, but not access certain ports (23 for telnet or 22 for ssh) makes me suspect your network interface has a firewall enabled on it. If the simulator is in a VM, make sure the guest O/S doesn't have a firewall enabled, or make sure ports for SSH, NDMP, HTTP, HTTPS, and SNMP are open.
If you're positive a firewall isn't the issue, provide more details about your environment's configuration.
2 REPLIES 2
reide
Natrian,
natrian_maxwell
Thans so much! So the issue was the firewall was off, but I had to enable the web services on my Mac. Yes I was running Ontap version 7.3 in a virtual environment.
