Network and Storage Protocols
NFS export to a specific IP range or to a Subnet Using Provisioning Manager
tanweer
Hi All,
While provisioning physical resource for NFS using Provisioning Manager, is it possible to export it to a specific IP range or to a subnet ?
It seems provisioning Manager limits you to export nfs to a specific ip address only.
Thanks
Tanweer
1 REPLY 1
PMSBoeblingen
check http://seriousbirder.com/blogs/netapp-nfs-exportfs-configuration-guide/
you can also nfs mount vol0 from the appropriate filer and edit /etc/exports manually.
