Network and Storage Protocols
Openssh errors and warnings
mazzucconi
Hello everyone,
while I'm connected to the filer, I see the following messages:
Wed Mar 7 10:20:28 CET [openssh.versionExchange.Fail:Error]: Did not receive identification string from [IP_ADDRESS].
Wed Mar 7 10:20:30 CET [openssh.dispatch.protocol:warning]: SSH dispatch failed from address [IP_ADDRESS], type 1, packet 5.
Does anyone know what this means and how to fix it?
Thank you in advance,
kind regards
5 REPLIES 5
crocker
This sounds a support related question.  We have external and internal subject matter experts in the NetApp Support Community answering questions.  If you have a NOW login you can ask in this area Filers.
Mike
columbus_admin
It looks like something is trying to login using SSH that is not sending proper information.  Searching on "openssh.versionExchange.Fail:Error" provides a lot of software patches for devices monitored by SSH calls.
I don't suppose you are using a product called LogicMonitor?
This site refers to their product simply checking/monitoring SSH status, so it generates bogus SSH calls, just to get a reply.  Maybe you have a monitoring system that does the same thing?
http://help.logicmonitor.com/notes-for-monitoring-specific-types-of-hosts/netapp-filers/
- Scott
LINUX43110
For anyone else that runs into this here is one possible solution: http://www.unixwitch.de/de/sysadmin/tools/netapp
Just disable the ServerAliveInterval on your ssh client for each of your filers since the filers don't seem to support it.
Do this by editing your .ssh/config in the client
Example:
# ~/.ssh/config
Host fas3240-a
     ServerAliveInterval 0
     Protocol 2
Host fas3240-b
     Protocol 2
Host fas3240-c
     Protocol 2
Host *
     ServerAliveInterval 2
     Protocol 2
jjeziorny
Hummm, somehow this didn't work for me. Still looking for a solution
JARED_OCKER
Changing the ServerAliveInterval was exactly the fix for the problem I was running into, but my warnings were a little different from the original poster:
Wed Jul 31 15:06:38 PDT [filername:openssh.dispatch.protocol:warning]: SSH dispatch failed from address [IP address], type 80, packet 191.
I log into a system that cuts off sessions after a short amount of time, so I had ServerAliveInterval set to 5 minutes on my Mac.  Unfortunately, this caused the NetApp to throw a warning on the console every 5 minutes when I was logged in.  I increased the interval and the console is *much* cleaner now.  Thanks!
.: Jared
