Network and Storage Protocols
NFS permission issue
BITBUCKET
I created a new volume, storage type NAS. The NFS share has Unix permissions allowing all hosts read and write. I can mount this volume on a windows machine, but it mounts read only. But, if I create a qtree inside of the volume, set to inherit volume security style, I can write files inside of the qtree.
What am I missing here?
2 REPLIES 2
HENRYPAN2
Hi Abdon,
You may wish to double check the volume security style which should be showing as 'UNIX'
Good luck
Henry
LTDCLSERGAO
Hello,
As I understand, you have created a volume witch is going to be used in the same time by unix and windows clients, right ?
