Network and Storage Protocols
Netapp fas8040 and MFPs Lexmark mx410de
pp
I have a MFPs Lexmark mx410de and I try to scan to a shared folder on a fas8040. MFPs is configured correctly. When I try to scan a document, I see right path to a shared folder, scanning process is successful, but I don't see the document in the folder. Folder permissions are correct. When I try to scan to a shared folder on another older netapp, all is ok. Anyone have any idea, how to solve this problem?
2 REPLIES 2
COMITSUPPORT
what do you see from the printer logs?
http://printerip/se
did you check my post http://community.netapp.com/t5/Network-Storage-Protocols-Discussions/CIFS-cDOT-8-3-and-Lexmark-MFPs/m-p/127691#M8669
thanks
pp
Yes, It is esf ver.4 and the latest firmware. Problem has been solved. I changed settings in EWS - "esf.scantonet.ntv4compatibility" from false on true and at the path to shared folder I added ".local" e.g. \\domain.local\....
