Network and Storage Protocols
Storage plugin for Rancher
DavidG
Hi all.
We are using Rancher for our customers' PaaS and we wonder if there is any project to create a Netapp storage plugin for Rancher. It would be great because many of our customers already use Netapp.
Br,
David.
1 ACCEPTED SOLUTION
asulliva
Hi @DavidG,
Thanks for reaching out.  To get the best information about our containers integrations I would recommend you visit the Slack channel(s) for thePub.  There's also lots of information about our containers integrations on thePub.
To directly answer your question, Rancher integration is something we're interested in, but nothing has been released at this point.  The containers Slack channel is a great place to interact with the team and voice your requests.
Hope that helps.
Andrew
If this post resolved your issue, please help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
2 REPLIES 2
Sahana
Hi,
Please refer https://netapp.github.io/blog/2016/04/19/announcing-the-netapp-docker-volume-plugin/
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
asulliva
Hi @DavidG,
Hope that helps.
Andrew
