Network and Storage Protocols
Sun Branded Emulex HBA's
bethel
All,
IHAC who has Solaris 9 u9 and wants to install SDU 4.1.1/SMO 3.0.2.  I can't find any HBA's that have a Sun part number that are certified for SDU.  I found some that are SAN supported, but not SDU supported.  If an HBA is SAN supported it it SDU supported?
Here is the HBA info:
                          Assembled 04 August 2005  LP10000-S
fcode-version     1.50a9
(Emulex-S s9-64 sparc v1.20g
Thanks,
Bethel
1 REPLY 1
adityav
Hey Bethel,
Solaris 9 u9 does not come with in-built drivers for FCP cards. Hence you will probably have to install vendor ( emulex) specific drivers. Although this card is not explicitly qualified with SDU it shoould work since we support similar cards on 9 u 9
