Network and Storage Protocols
What is the way to disable SSL 2.0 and 3.0 and use TLS 1.2?
novice
I got the following security violation notice on Netapp 8.2.2 (System Manager 3.1.3):
Description :
The remote service accepts connections encrypted using SSL 2.0 and/or
SSL 3.0. These versions of SSL are affected by several cryptographic
flaws, including:
- An insecure padding scheme with CBC ciphers.
- Insecure session renegotiation and resumption schemes.
Solution :
Consult the application's documentation to disable SSL 2.0 and 3.0.
Use TLS 1.2 (with approved cipher suites) or higher instead.
Thank you.
1 ACCEPTED SOLUTION
darb0505
Hi @novice ,
Here is a KB article that includes details to the security notice and how to disable SSL 2.0 and 3.0.
KB: How to disable SSLv2 and SSLv3 in Data ONTAP
Let us know if you have any questions regarding the steps to disable the SSL 2.0/3.0.  The KB includes steps for ONTAP 7-mode and cluster mode.
Thanks
Team NetApp
1 REPLY 1
darb0505
Hi @novice ,
Thanks
Team NetApp
