Network and Storage Protocols
Widelinks
krishrajan
Hi,
Has anyone successfully configured using widelinks?
The knowledgebase documents is not that useful.
We configured it but from cifs clients we get error "the location it refers is unavailable...."
Can you pl. post your experience?
We want to create soft links in netapp share which points to another NAS storage.
Thanks.
3 REPLIES 3
adamfox
I have done it.  The real trick is to get the symlinks and the translation table right.
Of course you start by enabling widelinks on the source share.
netapp> cifs shares -change vol1 -widelink
It should look like this in cifs shares:
vol1         /vol/data_vol1
             ... widelinks supported
                        everyone / Full Control
Then you create a symlink with a pattern that can be matched by the controller.  Note:  This path need not (and probably won't be) real.  Here's my example
lrwxrwxrwx 1 adamfox adamfox 18 2010-02-24 11:58 widelink -> /use/this/widelink
Then you have to create an entry in /etc/symlink.translations (note: the file may not exist by default) that describes the link you want.  Here's my example:
Widelink /use/this/widelink/* \\cosmo.rtpse.netapp.com\test
Now when I attach via cifs to the source (\\mojito.rtpse.netapp.com\vol1 in this case) I see a folder called "widelink".  If it shows up as a folder (since CIFS clients wouldn't know what to do with a symlink anyway), that's a good sign that it will work.  When I click on it, it passes me over to the "test" share on cosmo.  In this case, it's a NetApp controller, but it need not be since 'mojito' is just sending a DFS redirect to the client when it hits my link.
Of course I am assuming good permissions on the destination side.
This is a small example, but I think it shows how it really works.  The key is to come up with a pattern in the path of the link that can be matched by the symlink translator.
krishrajan
Adam,  Excellent. It works now! Thanks much for your help!
peluso
Adam,
Great post -- Chris Kranz references you on this topic (along with other good resources) here.....http://communities.netapp.com/groups/chris-kranz-hardware-pro/blog/2011/03/03/cifs-widelinks#cf
Terri
Thanks so much!
Terri Peluso
Senior Community Program Manager
