Network and Storage Protocols
network device-discovery show -protocol cdp - no entries
Brian_McCullough
I am re-installing (wipeconfig, new software first, yada, yada) an AFF-A300 nodes and hit something new.   I exit out of the setup at the (join / create) and turn on cdp (system node run -node localhost -command options cdpd.enable on) to validate as-built cabling matches expected/design.  The two AFF A300 nodes are showing lldp entries from three different cisco devices, but not any cdp entries for any device.   AFF-A300 running 9.14.1P5 (chosen to match FAS8200 cluster it will be eventually joining.)  The destination cluster pair of FAS8200s are connected to the c2921(light out management) and N5K data switches, and are receiving/sending CDP advertisements without issues.  So, all roads point to AFFs/ONATP as culprit.    Yes, each AFF can ping the cluster LIFs of the other node, both nodes rebooted.
It may be that nodes must be fully baked into a cluster before cdp actually works?
It may be something with this version and patch of ONTAP as fresh install, so OS change?
No technical case opened, yet, sharing the love first.
Will update when solved.
[Names and MAC Addr changed to protect the innocent until proven guilty]
::> network device-discovery show -fields protocol
node      protocol port discovered-device                        interface
localhost lldp     e0M  "c2921 (94:d4:69:00:00:00)"              Fa0/7
localhost lldp     e0a  "N9K-C9336C-FX2-01 (7c:ad:00:00:00:00)"  Ethernet1/1/2
localhost lldp     e0b  "N9K-C9336C-FX2-02 (a0:b4:00:00:00:00)"  Ethernet1/1/2
localhost lldp     e0e  "N5K-C5672UP-01 (00:2a:6a:00:00:00)"     Eth1/13
localhost lldp     e0f  "N5K-C5672UP-02 (8c:60:4f:00:00:00)"     Eth1/12
localhost lldp     e0g  "N5K-C5672UP-02 (8c:60:4f:00:00:00)"     Eth1/14
localhost lldp     e0h  "N5K-C5672UP-01 (00:2a:6a:00:00:00)"     Eth1/14
localhost lldp     e1a  "N9K-C9336C-FX2-02 (a0:b4:00:00:00:00)"  Ethernet1/2/2
localhost lldp     e1b  "N9K-C9336C-FX2-01 (7c:ad:00:00:00:00)"  Ethernet1/2/2
::> system node run -node localhost -command options cdpd
cdpd.enable                  on         (value might be overwritten in takeover)
cdpd.holdtime                180        (value might be overwritten in takeover)
cdpd.interval                60         (value might be overwritten in takeover)
::> system node run -node localhost -command options lldp
lldp.enable                  on         (value might be overwritten in takeover)
lldp.xmit.hold               4          (value might be overwritten in takeover)
lldp.xmit.interval           30         (value might be overwritten in takeover)
::> system node run -node localhost -command cdpd show-stats
RECEIVE
 Packets:             0  | Csum Errors:         0  | Unsupported Vers:    0
 Invalid length:      0  | Malformed:           0  | Mem alloc fails:     0
 Missing TLVs:        0  | Cache overflow:      0  | Received Own Adv:    0
 Other errors:        0  | Unknown TLV:         0  | Ejected entries:     0
 Eject failed:        0  | Bad Value:           0  | Hidden Port Drop:    0
TRANSMIT
 Packets:             0  | Xmit fails:          0  | No hostname:         0
 Packet truncated:    0  | Truncate fails:      0  | Mem alloc fails:     0
 Other errors:        0
OTHER
 Init failures:       0
::> system node run -node localhost -command lldp stats
RECEIVE
 Total frames:     6115  | Accepted frames:  6115  | Total drops:         0
TRANSMIT
 Total frames:     3331  | Total failures:      0
OTHER
 Stored entries:       9
N9K-C9336C-FX2-01# sh cdp interface Eth1/1/1
Ethernet1/1/1 is up
    CDP enabled globally
    CDP enabled on interface
    Refresh time is 5 seconds
    Hold time is 180 seconds
N9K-C9336C-FX2-01# sh cdp neighbors interface Eth1/1/1
Note: CDP Neighbor entry not found
N9K-C9336C-FX2-01#
N9K-C9336C-FX2-01# sh lldp neigh  interface Eth1/1/1
Capability codes:
  (R) Router, (B) Bridge, (T) Telephone, (C) DOCSIS Cable Device
  (W) WLAN Access Point, (P) Repeater, (S) Station, (O) Other
Device ID            Local Intf      Hold-time  Capability  Port ID
00a0.0000.0000       Eth1/1/1        121        S           e0a
Total entries displayed: 1
N9K-C9336C-FX2-01#
1 ACCEPTED SOLUTION
Brian_McCullough
Ok, that is solved, CDP is not fully enabled until node has joined a cluster.   So, I miss-remembered checking cdp for cabling before initial/basic cluster setup.  Ok, now to wipe and re-init cluster.  Thanks for tuning in.
test::> network device-discovery show -fields protocol -node test-02
test-02 cdp e0a N9K-C9336C-FX2-01(SN01) Ethernet1/1/2
test-02 cdp e0b N9K-C9336C-FX2-02(SN02) Ethernet1/1/2
test-02 cdp e0e N5K-C5672UP-01(SN03) Ethernet1/13
test-02 cdp e0f N5K-C5672UP-02(SN04) Ethernet1/12
test-02 cdp e0g N5K-C5672UP-01(SN03) Ethernet1/14
test-02 cdp e0h N5K-C5672UP-02(SN04) Ethernet1/14
test-02 cdp e1a N9K-C9336C-FX2-02(SN02) Ethernet1/2/2
test-02 cdp e1b N9K-C9336C-FX2-01(SN01) Ethernet1/2/2
test-02 lldp e0M "c2921 (94:d4:69:00:00:00)" Fa0/7
test-02 lldp e0a "N9K-C9336C-FX2-01 (7c:ad:00:00:00:00)" Ethernet1/1/2
test-02 lldp e0b "N9K-C9336C-FX2-02 (a0:b4:00:00:00:00)" Ethernet1/1/2
test-02 lldp e0e "N5K-C5672UP-01 (00:2a:6a:00:00:00)" Eth1/13
test-02 lldp e0f "N5K-C5672UP-02 (8c:60:4f:00:00:00)" Eth1/12
test-02 lldp e0g "N5K-C5672UP-01 (00:2a:6a:00:00:00)" Eth1/14
test-02 lldp e0h "N5K-C5672UP-02 (8c:60:4f:00:00:00)" Eth1/14
test-02 lldp e1a "N9K-C9336C-FX2-02 (a0:b4:00:00:00:00)" Ethernet1/2/2
test-02 lldp e1b "N9K-C9336C-FX2-01 (7c:ad:00:00:00:00)" Ethernet1/2/2
17 entries were displayed.
test::>
1 REPLY 1
Brian_McCullough
test::>
