Network and Storage Protocols
useradmin role and group will not work
richard_mackerras
Hi,
Our Service Desk want access to the filer to close open files. This seems to be a problem at shift changes where a file remains locked which another user needs to edit. The preferred access tool is "Computer Management" (or alternatively Hyena).
If I put a Service desk user, or the AD group created for the purpose into the "Power Users"  they can do what they need to do.
If I put a Service desk user, or the AD group created for the purpose into a group I defined, using a role I defined, they get access denied.
toaster> useradmin domainuser list  -g  "Power users"
List of SIDS in Power users
S-1-5-...
toaster> useradmin domainuser list  -g  isservicedesk
List of SIDS in isservicedesk
S-1-5-...
toaster> cifs lookup S-1-5-...
name = AD\System - NetApp Operators
I have not changed the "Power Users" group
toaster> useradmin group list "Power Users"
Info: Members that can share directories
Rid: 547
Roles: power
Allowed Capabilities: cli-cifs*,cli-exportfs*,cli-nfs*,cli-useradmin*,api-cifs-*,api-nfs-*,login-telnet,login-http-admin,login-rsh,login-ssh,api-system-api-*
toaster> useradmin role list power
Info:    Default role for power user privileges.
I have attempted to duplicate it twice, firstly with no NFS related access.
toaster> useradmin group list Service_Desk_Team
Info: HEAT 01062308 - Oracle Ent Mananger
Rid: 131083
Roles: op_api_cifs
Allowed Capabilities: cli-cifs*,cli-useradmin*,api-cifs-*,login-*,api-system-api-*
toaster> useradmin role list op_api_cifs
Info:    Service Desk Mananger - HEAT 01062308
That didn't work, so I added back in the NFS access, then I made an exact copy of "Power Users" with all new names.
toaster> useradmin group list isservicedesk
Info: TS Service Desk
Rid: 131084
Roles: issdrole
toaster> useradmin role list issdrole
Info:    CustServDesk
Why then is it that the Power Users group lets them do their work, but the groups I defined don't?
I have other groups to create for other people but there is no point proceeding if I can't understand this.
I practiced this on an old FAS270 DOT 7.3.3P5, I need it to work on an IBM N-6240 (FAS3240) running Data ONTAP Release 8.1.2P4. It has not worked on either.
What am I missing?
Thanks,
Richard Mackerras
1 ACCEPTED SOLUTION
LMEIRELES
Hi Richard,
I have the same problem.
Check this response from Netapp engineering:
Members of the custom users group doesn't have access to session management through MMC
http://support.netapp.com/NOW/cgi-bin/bol?Type=Detail&Display=748112
TITLE:
DESCRIPTION:
The users can manage the sessions through MMC, only if they belong to Administrators or "Power Users" group.  The other custom group members can't manage this, even though the group they belong to has the roles of
"admin" and/or "power".  This occurs because the access check for session management through MMC is based on the RID that is assigned to the group and not theroles of the group.
WORKAROUND:
No workaround exists this feature is by the design
Thanks,
Luis Meireles
2 REPLIES 2
LMEIRELES
Hi Richard,
TITLE:
DESCRIPTION:
WORKAROUND:
Thanks,
Luis Meireles
richard_mackerras
Hi Luis,
Thank you for the reply. I thought I must have been missing something really obvious because it didn't make sense and nobody else would engage with the question.
I have added the bug to my watch list.
Thank you for taking the time to post.
Richard
