Network and Storage Protocols
when vscan enable cifs shares too slow...
erkal
Hi,
I have trouble with virus scan option on my filer.
When I enable vscan option on N 3400 storage (I guess fas2040)  cifs shares being very slowly. While browse directory, copy or open file directly. Users complain because of this situation.
EX: . if vscan off, my file copy transfer rate (from filer to my desktop)  about 25-30 Mbps, if vscan on  then file copy transfer rate decrease 700-800 Kbps.
My environment :
Antivirus Server : Mcafee Virus Scan Enterprise + Antispyware Enterprise 8.7.0i (default setting) -  on Windows server 2008 r2 Ent.
Filer                 : N3300 - Ontap 7.3.3
Connection :  filer and A.Virus server are same local area and 100Mbit connection. Also my filer's 2 nics configured VIF multi mode.
vscan command print :
filer> vscan
Virus scanning is enabled.
Virus scanners(IP and Name)      P/S Connect time (dd:hh:mm)  Reqs    Fails    Curr. Reqs.
10.2.65.166     \\ITCserver           Pri    01:22:19               234        2        2
List of extensions to scan:
List of extensions not to scan:
Extensions-not-to-scan list is empty.
Number of files scanned:  234
Number of scan failures:  3
Number of throttled requests:  0
filer>
Not: Also I disabled vscan mandatory option. because sometimes users cannot access their files on filer.
I need your comments...
Thanks.
1 REPLY 1
pascalduk
With only a 100 Mbit connection to the virusscanner I would start checking if the network is full. If not then check if the virusscanner itself can handle the load and if the recommended settings have been set (https://now.netapp.com/Knowledgebase/solutionarea.asp?id=kb3378).
Also check if the filer itself has a cpu bottleneck by comparing cpu usage with vscan off/on.
