ONTAP Discussions
Cdot 8.3 with 10.1.0.0/16 single subnet for management and data broadcast domain
TonyWu
Hi experts
Please advise how to solve the limitation for cDOT 8.3 to limit the same subnet to be used between e0M and the data port
I can't create two subnet once the 10.1.0.0/16 being used in management network
All the data vserver is not able to assign up address
Please advise and there is no feedback from technical support
Thanks
Tony
7 REPLIES 7
shatfield
In your design, is the network with the 10.1/16 subnet that e0M is connected to the same network that the data ports are connected to? Or are you using the same/overlapping address ranges on two completely separate networks?
TonyWu
Hi Sean
The e0M and data port will share the 10.1/16
This is an end user unit and there is no need to use multi tenant
Thanks
Tony
shatfield
Is there some reason they can't be in the same broadcast domain?  Different MTU perhaps?
TonyWu
Hi Sean
The setting of the subnet rejected in on command manager
shatfield
So...
The broadcast domain exists
it contains e0M and other Data ports
The subnet exists
The subnet is associated with the correct broadcast domain
It has available IPs
but:
you get an error when you create the lif on the network interfaces tab?
or are you getting the error when you create the SVM?
either way, whats the error message?
TonyWu
Hi Sean
"The subent is being used"
So it doesn't allow me to create
Tony
shatfield
If it already exists, use the one you have.
