ONTAP Discussions
Connect-NcController using current context
JBRUNS2012
Using the dataontap 4.4 powershell toolkit to try to connect to a cDOT cluster/vserver and I have it working but one question.
Is there no way to tell the command to use the currently logged on user token?  Do I have to prompt for the users credentials even though they are right there in the windows address space to use?
When I use the connect-nacontroller, I only need to supply the -name parameter and it uses the currently logged on user.
11 REPLIES 11
mbeattie
Hi,
The -Credential parameter of the "Connect-NcController" cmdlet has a mandatory value of False and can be used with cached credentials.
See "Get-Help Add-NcCredential -Full"
NAME
    Add-NcCredential
SYNOPSIS
    Save login credentials for a clustered Data ONTAP controller.
SYNTAX
    Add-NcCredential [-Credential <PSCredential>] [-SystemScope] [<CommonParameters>]
    Add-NcCredential -Controller <NcController[]> [-Credential <PSCredential>] [-SystemScope] [<CommonParameters>]
    Add-NcCredential [-Name] <String> [-Credential <PSCredential>] [-SystemScope] [<CommonParameters>]
DESCRIPTION
    Save login credentials for a clustered Data ONTAP controller.  The cached credentials are available to
    Connect-NcController, Invoke-NaSsh, and other Toolkit cmdlets.
    The saved credentials are encrypted for safe storage.  By default, a set of credentials is saved using the current
    user context, so that only the same Windows user can retrieve them.  If an application of the Toolkit must utilize
    the cached credentials while running under some other context, specify the -SystemScope parameter.  This saves the
    credentials such that any process or user on the local system can access them, so this option should only be used
    on a system with limited user access.
    Any number of Toolkit users may store credentials for a given storage controller in the cache, but a user will
    only be able to see and utilize credentials saved using his account identity or the system identity.
/Matt
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
JBRUNS2012
I'm trying to avoid having the user provide their password at all.  Are you trying to tell me that add-nccredential will use the current context and avoid having to supply the currently logged on user credentials?
mbeattie
Hi,
Yes that's correct. You can cache the credentials you want to use for the current logged on user then connect to the cluster without providing credentials as they can be retrieved from the cache if not provided to connect-nccontroller cmdlet. EG
PS C:\> Add-NcCredential -Name cluster2.testlab.local -Credential $(Get-Credential -Credential admin)
Name                                                        Credential                                                  HostUser
cluster2.testlab.local                                      System.Management.Automation.PSCredential                   TESTLAB\mbeattie
PS C:\> Connect-NcController -Name cluster2.testlab.local
Name                 Address           Vserver              Version
cluster2.testlab.... 192.168.100.3                          NetApp Release 9.1: Thu Dec 22 23:05:58 UTC 2016
/Matt
JBRUNS2012
Your example highlights my fear.
You are still at least one time using this argument ...
I am trying to avoid using it at all, like connect-nacontroller does.
I am not using local users either, I will be using Active Directory accounts.
scottharney
add-nccredential populates the local logged in user's credentials cache. So get-nccredential will show you the contents of your particular on disk local credentials cache.  You can add-nccredential for a system using an AD account but it would only be in your credentials cache and if the user account you supply isn't the currently logged in user it would prompt you one time for the password for that AD account.  once it's in the cache, you wouldn't have to use the password again.  you can then connect-nccontroller as you expect.
Mostly this would work without you needing to manage the credentials cache.  If the currently logged in AD account has admin role on the cluster (or an appropriate assigned role) and you do $mycontroller1 = connect-nccontroller cluster_hostname it will log in without prompting for you AD password even once. I tend to supply -Controller $mycontroller to all cmdlets explicitly when I'm working with powershell because I am usually working across more than one controller, eg get-ncvol -controller $mycontroller1 .
you can use add-nccredential as he already shown to populate the cache on a machine.  So you can do add-nccredential -controller cluster_name -credential (get-credential) and simply supply your AD login and password at the prompt.  get-nccredential will then reflect this added cached credential and a subsequent call to connect-nccredential to the same "controller" already contained in the credentials cache will connect without password prompt. This will persist across reboots as the credentials cache is encrypted on disk.  get-help add-nccredential -detailed and the related cmdlets for more info
JBRUNS2012
Bottom line sounds like with cDOT and Powershell, a person has to supply the AD account password once.
Imagine yourself as the user of a script and you know you are already logged on to the machine where you plan on running the script from and when you run the script, you get prompted for password?
My first impression would be "why in the hell don't they just use the windows cached token and pass that in?"
connect-nacontroller has no issue in this area and that is how connect-nccontroller should have been designed.
scottharney
no. That's not the case. IF the user is logged in as an AD user that has the right role on the cluster an the cluster is appropriately configured to use RBAC roles with AD accounts then connectiion to the filer will not prompt for password.
If you are getting prompted for a password when you connect to the controller with connect-nccontroller I would expect one of two possibilities
  1. you are not logged in to your windows machine using the AD account that has the appropriate role to manage the filer
  2. you don't have the filer configured to allow your AD account to manage it. (see also: https://library.netapp.com/ecm/ecm_download_file/ECMLP2496262 )
JBRUNS2012
Thank You for that clarification.
Now, with OnTap 8.2.x, is this available since the manual you sent me is 9.x?
scottharney
https://library.netapp.com/ecmdocs/ECMP1368701/html/GUID-BC7B1934-DDE6-4AFB-A319-6C85D1ADACB6.html is 8.2.x . There have been changes from 8.2.x to 8.3 and beyond with regards to active directory configuration and access to cluster management.
JBRUNS2012
Is there a road map of those changes as they relate to AD access to cDOT clusters starting with 8.2 someplace?
scottharney
You would be diggining in to release notes primarily.  The documentation for different versions for System administration also. Docs for 8.3.x release notes are here
https://mysupport.netapp.com/documentation/docweb/index.html?productID=62227&language=en-US
it talks briefly about the udpated actived directory support for cluster and svm adminsitrators and then directs you to the detailed system administration guide.  I don't believe there are changes between 8.3.x and 9.x with regards to this but as I recall (from personal memory so take with a grain of salt) there were changes between 8.2.1+ and 8.3.x .
