ONTAP Discussions
Data ontap edge
MJABER
hello all ,
any one did try Data Ontap Edge ?
can any one tell us what it is ?
2 REPLIES 2
venkat3
Hello. welcome to communities.
Please find information about data ontap edge in the below link
http://www.netapp.com/in/products/platform-os/data-ontap-edge/
-srinivas
paulstringfellow
The link in the other reply gives you what you need.
but in essence, OnTap edge is a virtual version on DataOntap that can be deployed in an ESX OVS file, it's fully functional and delivers all of the OnTap features you would expect on a hardware array.
there are some limitations in terms of size etc... it is basically designed for remote office where you potentially don't want a hardware box and maybe you ship a single machine with multiple VM's as part of a remote office strategy.
once the data in on edge it can be mirrored, vaulted etc to central sites for protection purposes.
hope that helps
