ONTAP Discussions
Does maximum vol size for device include WAFL reserve?
WSANDERSATFLEXERA
Does maximum vol size for device include WAFL reserve or something nonobvious like that? Looks like the usable max vol size for 8.1.4 on a 3240 is actually quite a bit less than 50T as  claimed in HW Universe:
> vol size vol4
vol size: Flexible volume 'vol4' has size 48318381160k.
> vol size vol4 +1m
vol size: Request to grow volume 'vol4' failed because the resulting volume size is greater than the maximum size.
That's only about 44T in 1024x1024x1024 units. We recently upgraded OnTAP from 8.0.2 to 8.1.4 to get a bigger aggregate size, but 8.1.4 upgrade only got me an additional 1TB max volume size. We were able to grow the aggregate to 48TB, so there is plenty of space in the aggregate. There are about 20 qtrees on the volume, but quota is off for the volume. SIs is on for the system, but not configured for this volume.
Snap reserve for this volume is 0 and nosnap is ON:
> vol options vol4
nosnap=on, nosnapdir=off, minra=off, no_atime_update=off, nvfail=off,
ignore_inconsistent=off, snapmirrored=off, create_ucode=on,
convert_ucode=on, maxdirsize=73400, schedsnapname=ordinal,
fs_size_fixed=off, guarantee=volume, svo_enable=off, svo_checksum=off,
svo_allow_rman=off, svo_reject_errors=off, no_i2p=off,
fractional_reserve=100, extent=off, try_first=volume_grow,
read_realloc=off, snapshot_clone_dependency=off, dlog_hole_reserve=off,
nbu_archival_snap=off
chesdfiler1a> vol status vol4
         Volume State           Status            Options
           vol4 online          raid_dp, flex     nosnap=on, create_ucode=on, convert_ucode=on
                                64-bit
                         Volume UUID: 4f3ec690-9acb-11e0-95ee-00a09816961c
                Containing aggregate: 'aggr2'
> aggr show_space aggr2
Aggregate 'aggr2'
    Total space    WAFL reserve    Snap reserve    Usable space       BSR NVLOG           A-SIS          Smtape
  57279822336KB    5727982232KB             0KB   51551840104KB             0KB             0KB             0KB
Space allocated to volumes in the aggregate
Volume                          Allocated            Used       Guarantee
vol4                        48586816616KB   47413626408KB          volume
Aggregate                       Allocated            Used           Avail
Total space                 48586816616KB   47413626408KB    2961725708KB
Snap reserve                          0KB             0KB             0KB
WAFL reserve                 5727982232KB     400065692KB    5327916540KB
1 ACCEPTED SOLUTION
WSANDERSATFLEXERA
There is some fine print. At the bottom of each hardware universe page"
3
The maximum usable aggregate capacity is roughly 90% of the values shown in the "Aggregate Size 32 bit(TB)" rows.
4
The maximum usable aggregate capacity is roughly 90% of the values shown in the "Aggregate Size 64 bit(TB)" rows.
5
The maximum usable FlexVol capacity is roughly 90% of the values shown in the "Flex Volume Size 32 bit(TB)" rows.
6
The maximum usable FlexVol capacity is roughly 90% of the values shown in the "Flex Volume Size 64 bit(TB)" rows.
This is misleading and inaccurate. I have created volumes that fill up 100% of the space of an aggregate (as sown by df -A), and volumes fill up to 100% of "usable space" all the time. Perhaps the fine print means "maximum size" instead of "maximum usable capacity"? In which case 88% for volumes is a more reasonable figure.
5 REPLIES 5
JGPSHNTAP
Its easier if you look at the commands in the right context
df -Vh
df -Ah
can we see both those outputs
WSANDERSATFLEXERA
> df -Vh vol4
Filesystem               total       used      avail capacity  Mounted on
/vol/vol4/                44TB       44TB     1013GB      98%  /vol/vol4/
/vol/vol4/.snapshot        0GB       21GB        0GB     ---%  /vol/vol4/.snapshot
> df -Ah
Aggregate                total       used      avail capacity
aggr2                     48TB       45TB     2824GB      94%
aggr2/.snapshot            0TB        0TB        0TB     ---%
JGPSHNTAP
hmm.. Not sure..
billshaffer
The max volume size includes the 1% aggregate overhead and 10% volume overhead, or at least it did in 7.3.  I worked out a spreadsheet once in order to determine the optimum backend lun size for a V-Series needed to maximize the volume usable space, and had to take both figures into account.  I also had to take into account the checksum overhead - though I hear that, with native NetApp disk, that has gone away.
Bill
WSANDERSATFLEXERA
3
4
5
6
