ONTAP Discussions
Error while loading while connecting using NetApp.ONTAP module on Linux.
stephenbuchanan
Does the module supports Linux?
PWSH: Connect-NaController mycontroller
Connect-NaController: Unable to load shared library 'kernel32.dll' or one of its dependencies. In order to help diagnose loading problems, consider setting the LD_DEBUG environment variable: libkernel32.dll: cannot open shared object file: No such file or directory.
I also tried using another module called dataontp but it threw pssapin errors on my Linux machine every time I tried importing.
Import-Module: Could not load type 'System.Management.Automation.PSSnapIn' from assembly 'System.Management.Automation, Version=7.2.1.500, Culture=neutral, PublicKeyToken=31bf3856ad364e35
2 REPLIES 2
Ontapforrum
Never tried on linux, but just make sure the installation requirements are met for linux.
https://mysupport.netapp.com/site/tools/tool-eula/ontap-powershell-toolkit
Installation requirements for Linux using RHEL.
Operating system Version: RHEL 7 | Microsoft Windows PowerShell 7.0.3 and later
For redhat or other *nixes, Install instruction are given in this pdf .
https://mysupport.netapp.com/api/tools-service/toolsbinary/ontap-powershell-toolkit/download/NetApp%20PowerShell%20Toolkit%209.11.1%20Cmdlet%20Excepti...
TMACMD
Also, the “Na” commands are for 7 mode controllers. Look at the “Nc” commands when you get powershell working
