ONTAP Discussions
FAS2240 and Clustered Mode Advanced Partitioning
drhermi
Hi,
I want to upgrade my FAS2240 to Cluser Mode.
Please tell me if there is posibillity to use Advanced Partitioning Mode on this FAS ?
Konrad
1 ACCEPTED SOLUTION
GidonMarcus
Yes, you can (hwu.netapp.com).
just heads up - it's not an upgrade- its require to reinstall. and you will need cluster mode licenses.
good luck
Gidi Marcus (Linkedin) - Storage and Microsoft technologies consultant - Hydro IT LTD - UK
4 REPLIES 4
GidonMarcus
good luck
drhermi
Hi,
Yes, I know that I need reinstall whole Ontapp. but tell me if the Advanced Partitioning (AP) is available immediately after install cluster mode or I need do something during Install to initialize this excellent thing ?
I know that Advanced partitionig isn't available on FAS80XX.
The system during installation detect hardware version and use AP or not ?
Thanks
Konrad
Sid
Hi,
Boot into maintenance mode from the boot menu and unassign all drives from each node
Then Reboot each node, and then choose option 4 – wipeconfig.
Once the wipe is finished, the system will use ADP on the internal drives and be ready to setup.
Regards
Sid
NetApp Instructor, IT Learning Solutions http://sg.itls.asia/netapp
(P.S. I appreciate 'kudos' on any helpful posts.)
georgevj
Adding a note here.
The system must be running Data ONTAP 8.3 or later.
If this post resolved your issue, help others by selecting ACCEPT AS SOLUTION or adding a KUDO.
Cannot find the answer you need? No need to open a support case - just CHAT and we’ll handle it for you.
