ONTAP Discussions
FAS2520 aggr0 double degraded, replacement drives detected as SAS 15000
Zeam
Case description:
FAS2520 / Data ONTAP 7-Mode: aggr0 double degraded, replacement drives detected as SAS 15000 and not accepted as matching spares, maintenance disk stuck in testing.
Current problem
  • aggr0 is currently double degraded.
  • The RAID group shows two FAILED data members.
  • We have available spare disks, but the system is not using them for rebuild.
  • A maintenance disk (0a.00.3) remains in testing status.
Observed behavior
From aggr status -r:
  • Aggregate aggr0 (online, raid_dp, degraded) (block checksums)
  • RAID group /aggr0/plex0/rg0 (double degraded, block checksums)
  • Two data positions in the RAID group show as FAILED
From aggr status -s:
  • Current spare disks are:
    • 0a.00.1 → SAS 15000
    • 0a.00.8 → SAS 15000 (at one point shown as not zeroed)
  • Existing RAID group members are shown as FSAS 7200
  • Maintenance disks section shows:
    • 0a.00.3 → testing, FSAS 7200
From disk show -v:
  • 0a.00.3 shows OWNER = FAILED
Drive identification inconsistency
From storage show disk -T -x:
  • 0a.00.1 and 0a.00.8 are identified as:
    • Model = X477_SMBPE04TA07
    • Rev = NA00
    • Type = SAS
  • Most other data disks in the shelf are identified as:
    • Model = X477_SMEGX04TA07
    • Rev = NA03
    • Type = FSAS
We also replaced the disk in slot 0a.00.8 with another brand-new replacement drive, but the newly inserted disk was still detected as SAS / RPM 15000.
What we already checked
  • raid.disktype.enable = off
  • raid.rpm.ata.enable = off
  • Broken disks (empty) from aggr status -f
  • Current spare disks are owned by the controller and use block checksum
  • Another new replacement drive inserted into 0a.00.8 still shows as SAS 15000
Our concern
It appears that the available replacement drives are not being accepted as valid matching spares for aggr0, possibly because the RAID group members are shown as FSAS 7200 while the replacement drives are detected as SAS 15000.
We need help with
  1. Please confirm whether the replacement drives/FRUs are correct for this platform and RAID group.
  2. Please confirm whether there is a disk qualification / drive firmware / recognition issue causing the system to identify replacement drives as SAS instead of FSAS.
  3. Please advise the supported recovery procedure for aggr0 in the current double degraded state.
  4. Please advise how to handle maintenance disk 0a.00.3, which remains in testing and also appears as OWNER = FAILED.
Commands / outputs available
We can provide the outputs of:
  • aggr status -r
  • aggr status -s
  • aggr status -f
  • storage show disk -T -x
  • storage show disk -x
  • sysconfig -d
  • disk show -v
  • options raid.disktype.enable
  • options raid.rpm.ata.enable
Please advise next steps.
Best regards
12 REPLIES 12
Zeam
Update some outputs:
sn7047064-stor*> sysconfig -d
Device      HA  SHELF BAY CHAN   Disk Vital Product Information
0a.00.0     0a  0     0   SA:A   ZC12C9EB
0a.00.1     0a  0     1   SA:A   ZC12SJ8R
0a.00.2     0a  0     2   SA:A   Z1ZBWY1P
0a.00.3     0a  0     3   SA:A   Not available.
0a.00.4     0a  0     4   SA:A   Z1ZBWYYP
0a.00.5     0a  0     5   SA:A   Z1ZBWZX1
0a.00.6     0a  0     6   SA:A   Z1ZBWXZG
0a.00.7     0a  0     7   SA:A   Z1ZBWZFN
0a.00.8     0a  0     8   SA:A   ZC12SH5E
0a.00.9     0a  0     9   SA:A   Z1ZBWZYZ
0a.00.10    0a  0     10  SA:A   Z1ZBWXWD
0a.00.11    0a  0     11  SA:A   Z1ZBWQ3W
sn7047064-stor*> storage show disk -T -x
DISK      SHELF BAY SERIAL    VENDOR  MODEL             REV  TYPE
0a.00.1   0     1   ZC12SJ8R  NETAPP  X477_SMBPE04TA07  NA00 SAS
0a.00.8   0     8   ZC12SH5E  NETAPP  X477_SMBPE04TA07  NA00 SAS
0a.00.0   0     0   ZC12C9EB  NETAPP  X477_SMBPE04TA07  NA00 FSAS
0a.00.2   0     2   Z1ZBWY1P  NETAPP  X477_SMEGX04TA07  NA03 FSAS
0a.00.3   0     3   Z1ZBWS35  NETAPP  X477_SMEGX04TA07  NA03 FSAS
0a.00.4   0     4   Z1ZBWYYP  NETAPP  X477_SMEGX04TA07  NA03 FSAS
0a.00.5   0     5   Z1ZBWZX1  NETAPP  X477_SMEGX04TA07  NA03 FSAS
0a.00.6   0     6   Z1ZBWXZG  NETAPP  X477_SMEGX04TA07  NA03 FSAS
0a.00.7   0     7   Z1ZBWZFN  NETAPP  X477_SMEGX04TA07  NA03 FSAS
0a.00.9   0     9   Z1ZBWZYZ  NETAPP  X477_SMEGX04TA07  NA03 FSAS
0a.00.10  0     10  Z1ZBWXWD  NETAPP  X477_SMEGX04TA07  NA03 FSAS
0a.00.11  0     11  Z1ZBWQ3W  NETAPP  X477_SMEGX04TA07  NA03 FSAS
sn7047064-stor*> aggr status -s
Pool1 spare disks (empty)
Pool0 spare disks
RAID Disk  Device   HA  SHELF BAY CHAN Pool Type RPM    Used (MB/blks)       Phys (MB/blks)
Spare disks for block checksum
spare      0a.00.1  0a  0     1   SA:A 0    SAS  15000  3807816/7798408704   3815447/7814037168
spare      0a.00.8  0a  0     8   SA:A 0    SAS  15000  3807816/7798408704   3815447/7814037168 (not zeroed)
sn7047064-stor*> aggr status -f
n7047064-stor*> aggr status -r
  Plex /aggr0/plex0 (online, normal, active)
      dparity    0a.00.11  0a  0     11  SA:A 0    FSAS 7200  3807816/7798408704   3815447/7814037168
      parity     0a.00.0   0a  0     0   SA:A 0    FSAS 7200  3807816/7798408704   3815447/7814037168
data       0a.00.2   0a  0     2   SA:A 0    FSAS 7200  3807816/7798408704   3815447/7814037168
      data       FAILED
      data       0a.00.4   0a  0     4   SA:A 0    FSAS 7200  3807816/7798408704   3815447/7814037168
      data       0a.00.5   0a  0     5   SA:A 0    FSAS 7200  3807816/7798408704   3815447/7814037168
      data       0a.00.6   0a  0     6   SA:A 0    FSAS 7200  3807816/7798408704   3815447/7814037168
data       0a.00.7   0a  0     7   SA:A 0    FSAS 7200  3807816/7798408704   3815447/7814037168
      data       FAILED
      data       0a.00.9   0a  0     9   SA:A 0    FSAS 7200  3807816/7798408704   3815447/7814037168
      data       0a.00.10  0a  0     10  SA:A 0    FSAS 7200  3807816/7798408704   3815447/7814037168
Pool0 spare disks
Maintenance disks
testing    0a.00.3  0a  0     3   SA:A 0    FSAS 7200  3807816/7798408704   3815447/7814037168
sn7047064-stor*> disk show -v
DISK      OWNER                         POOL   SERIAL NUMBER  HOME                          DR HOME  CHKSUM
0a.00.8   sn7047064-stor(537073381)     Pool0  ZC12SH5E       sn7047064-stor(537073381)             Block
0a.00.0   sn7047064-stor(537073381)     Pool0  ZC12C9EB       sn7047064-stor(537073381)             Block
0a.00.10  sn7047064-stor(537073381)     Pool0  Z1ZBWXWD       sn7047064-stor(537073381)             Block
0a.00.4   sn7047064-stor(537073381)     Pool0  Z1ZBWYYP       sn7047064-stor(537073381)             Block
0a.00.7   sn7047064-stor(537073381)     Pool0  Z1ZBWZFN       sn7047064-stor(537073381)             Block
0a.00.6   sn7047064-stor(537073381)     Pool0  Z1ZBWXZG       sn7047064-stor(537073381)             Block
0a.00.2   sn7047064-stor(537073381)     Pool0  Z1ZBWY1P       sn7047064-stor(537073381)             Block
0a.00.11  sn7047064-stor(537073381)     Pool0  Z1ZBWQ3W       sn7047064-stor(537073381)             Block
0a.00.5   sn7047064-stor(537073381)     Pool0  Z1ZBWZX1       sn7047064-stor(537073381)             Block
0a.00.9   sn7047064-stor(537073381)     Pool0  Z1ZBWZYZ       sn7047064-stor(537073381)             Block
0a.00.3   FAILED                        -----  Z1ZBWS35       sn7047064-stor(537073381)             Block
0a.00.1   sn7047064-stor(537073381)     Pool0  ZC12SJ8R       sn7047064-stor(537073381)             Block
Zeam
Update ouputs:
Pool0 spare disks
sn7047064-stor*> aggr status -r
      data       FAILED
      data       FAILED
Pool0 spare disks
Maintenance disks
Zeam
One additional question: disk 0a.00.0 and disk 0a.00.1 appear very similar in the visible outputs (same vendor/model family and revision), but ONTAP identifies 0a.00.0 as FSAS/7200 in RAID view while 0a.00.1 is identified as SAS/15000 spare. Please help confirm whether this is due to DQP/drive qualification/firmware recognition or another disk-type mapping issue.
Zeam
Update System information:
- Storage system name: sn7047064-stor
- Model: FAS2520
- Data ONTAP version: 8.2.4 7-Mode
- System ID: 0537073381
- Management IP: 10.67.47.92
Zeam
Zeam
Zeam
      data       FAILED
      data       FAILED
Pool0 spare disks
Maintenance disks
Zeam
Zeam
Zeam
In OnCommand System Manager, I right-clicked spare disk 0a.00.1 and selected "Add to Aggregate".
A warning was shown first:
"OnCommand System Manager does not recommend adding disks to an aggregate from this page..."
After clicking Continue, the system returned this error:
"No existing aggregates available to which you can add the selected disk(s). Select some other disks."
This suggests that the controller does not consider 0a.00.1 eligible to be added to any existing aggregate, including aggr0.
Drew_C
Hi @Zeam, the replies with additional information were inadvertently marked as spam. I've cleared the flag and they're now posted here. Apologies for the system error.
Community Manager \\ NetApp
Zeam
Ok, seems there is no other solution for this HDD. Maybe need exactly same HDD to solve.
