ONTAP Discussions
FPolicy: Is there a way to configure retry backoff/interval for max-connection-retries for connection from SVM to Fpolicy server ?
Adarsh
We are using an asynchronous FPolicy engine to collect file audit events from ONTAP.
As shown in the logs below, when FPolicy server goes down, ontap exhausts all 20 of its configured reconnect attempts in just 39 seconds (from 09:41:48 to 09:42:27). Once these retries are exhausted, the engine transitions to a permanent disconnected state (TCP Connection to FPolicy server failed) and  does not auto-reconnect when the server comes back online even after a minute.
Event logs in the diagnostic mode -
Time                Node                      Severity  Event
7/15/2026 09:42:27  FsxId04eda4994b6009ffe-01 ERROR     fpolicy.server.connectError: Node failed to establish a connection with the FPolicy server "x.y.z.z" of policy "cloud_poc_policy" for Vserver ntfs-fsx (reason: "TCP Connection to FPolicy server failed.").
7/15/2026 09:42:27  FsxId04eda4994b6009ffe-02 ERROR     fpolicy.server.connectError: Node failed to establish a connection with the FPolicy server "x.y.z.z" of policy "cloud_poc_policy" for Vserver ntfs-fsx (reason: "TCP Connection to FPolicy server failed.").
7/15/2026 09:41:48  FsxId04eda4994b6009ffe-01 ERROR     fpolicy.server.disconnect: Connection to the FPolicy server "x.y.z.z" of policy "cloud_poc_policy" is broken for Vserver ntfs-fsx ( reason: "Connection to FPolicy server is broken(EPIPE) received." ).
7/15/2026 09:41:48  FsxId04eda4994b6009ffe-02 ERROR     fpolicy.server.disconnect: Connection to the FPolicy server "x.y.z.z" of policy "cloud_poc_policy" is broken for Vserver ntfs-fsx ( reason: "Connection to FPolicy server is broken(EPIPE) received." ).
Engine Config -
 vserver fpolicy policy external-engine show -vserver ntfs-fsx -engine-name cloud_poc_engine -instance
                                        Vserver: ntfs-fsx
                                         Engine: cloud_poc_engine
                        Primary FPolicy Servers: x.y.z.z
                 Port Number of FPolicy Service: 32200
                      Secondary FPolicy Servers: -
                           External Engine Type: asynchronous
          SSL Option for External Communication: no-auth
                Timeout for Canceling a Request: 20s
                 Timeout for Aborting a Request: 40s
           Interval for Sending Status Requests: 30s
                          Max Reconnect Attempt: 20
Maximum Outstanding Requests for FPolicy Server: 500
Timeout for Disconnecting Non-responsive Server: 100s
       Interval for Sending Keep-Alive Messages: 2m
                     FQDN or Custom Common Name: -
                   Serial Number of Certificate: -
                          Certificate Authority: -
                            Receive Buffer Size: 262144
                               Send Buffer Size: 1048576
   Session ID Purge Timeout During Reconnection: 10s
                  Is Resiliency Feature Enabled: true
        Maximum Notification Retention Duration: 10m
             Directory for Notification Storage: /data/
                         External Engine Format: xml
Policy config -
                        Vserver: ntfs-fsx
                         Policy: cloud_poc_policy
              Events to Monitor: cloud_poc_event
                 FPolicy Engine: cloud_poc_engine
Is Mandatory Screening Required: false
        Allow Privileged Access: no
User Name for Privileged Access: -
    Is Passthrough Read Enabled: false
          Persistent Store Name: -
Documentation https://docs.netapp.com/us-en/ontap/nas-audit/plan-fpolicy-external-engine-config-concept.html#what-the-advanced-external-engine-options-are  doesn't have any info on this.
0 REPLIES 0
