ONTAP Discussions
How long are alerts there for? Is it triggered and then active for 24 hours?
Northman
Yesterday I attached a DS460c shelf to a FAS2720 with HA cabling. Sysconfig command shows HA, and all the disks have path A and B (storage disk -path). But the alert "SinglePathtoDiskShelf_Alert" is still active.
I think this is ok, but for the future, should I:
A. Suppress this alert
B. Delete this alert?
Will it come back if it is valid in both cases?
1 ACCEPTED SOLUTION
Ontapforrum
If you have checked and confirm that:
  1. SAS cabling is correct and in MultiPath
  2. Clear the alert
::> system health alert delete -alert-id * -alerting-resource *
You might want to check the output of these commands:
::> system health alert show
::> storage shelf show -connectivity
::> storage show disk -field path-count
However, if there is a missing path, then troubleshoot it or simply raise a NetApp ticket for a review.
https://kb.netapp.com/onprem/ontap/hardware/%22SinglePathToDiskShelf_Alert_%22and_%22DISK_REDUNDANCY_FAILED%22_Autosupport_triggered
"SinglePathToDiskShelf_Alert "and "DISK REDUNDANCY FAILED" Autosupport triggered - NetApp Knowledge Base
1 REPLY 1
Ontapforrum
  2. Clear the alert
