ONTAP Discussions
How to deduplicate and compress data blocks locked by snapshot
Chun_Chiang
I need to clarify whether ONTAP can dedup and compress data blocks locked by snapshot.  Does below command
vol efficiency start -volume vol1 -vserver vs1 -scan-all -shared-blocks -snapshot-blocks
dedup and compress data blocks locked by snapshot ?
if not, does it mean snapshot blocks can not be deduplicated or compressed ?
Regards,
Chun Chiang
1 ACCEPTED SOLUTION
chenguanghui
hello:
        by default,data compression skips data block shared by Data deduplication and data blocks that are locked by Snapshot copies,the following article be maybe help for you.
https://docs.netapp.com/zh-cn/ontap/volumes/run-efficiency-operations-manual-existing-data-task.html
2 REPLIES 2
chenguanghui
hello:
Chun_Chiang
According to the article, this command:
vol efficiency start -scan-old-data true -dedup true
can dedup existing data blocks which are locked by snapshot, right?
